1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
  • Firentiosi
    Hobbyist
    • May 2021
    • 5
    Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
    The issues are as follows: the left-hand 1/3rd of the screen is black, no image and occasionally has vertical multicoloured lines. The backlight is functioning on the TV and shining a flashlight doesn't show any image.
    The circuitry has a power supply unit and a TCON board (CHOT CV580U1)
    Voltages measured are as follows:
    12Vin - 12.49V
    VBo 0.03V
    VSS1 7V
    RVAA 15V
    LVAA 15V
    VGHF 7.7V
    VGL -8.8V
    There are also 1.2V, 3.3V, 12V and 15V DC power rails present.
    The TCON board connects to a LEFT and a RIGHT sub-panels. Each sub panel has multiple connections (chip-on-film, I believe) to the panel/LED circuitry. If a third of the screen is not working, then perhaps it is something to do with a short or open circuit 'upstream' of the three COF strips that feed the leftmost third of the board?
    I have attempted to unseat and reseat the mainboard -> TCON board ribbon strip and TCON--> sub-panel ribbon strips.
    1. How can one tell if it is the LED strips themselves vs another component? I see that these strips are usually arranged horizontally, but my issue is a vertical one. Perhaps I am naively thinking that it is not the actual LEDs?
    Any further information or troubleshooting greatly appreciated.
  • Firentiosi
    Hobbyist
    • May 2021
    • 5
    Ah, found it. Crack in the LCD right where I'd expect it. Thanks anyway guys.
    • KYBOSH
      • Oct 2011
      • 581
      • Unknown
      For me... vertical lines means "dont bother"
      Usually a tab bond issue and not really a crack in the screen.
      But you can learn from this TV set.
      Its a junker but you can have a look around to get a feel of what's what.
      So next time you have a set you are trying to save you'll have a better understanding of things.
      Good luck
      • Firentiosi
        Hobbyist
        • May 2021
        • 5
        Thank you! Yes, I'd learned as much as I could from this set. Just the basics, but was still informative.
        • Stanley1843
          by Stanley1843
          06-29-2024, 11:54 AM
        • Falki
          Colorful LCD Vertical Lines on Samsung ue55es8090
          by Falki
          Hello there, ive recently found an older 55inch Samsung SmartTV.
          A similar issue has been posted as well but also with no actual response ...
          08-12-2025, 04:19 AM
        • visionbluedemon
          Help. Sony kd-65x85dj vertical lines
          by visionbluedemon
          First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
          Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
          tried blocking LC lines too, but same results
          is it lcd panel issue or tcon board issue?...
          07-25-2025, 04:56 AM
        • gpo23
          Sony KDL-40V3000 - Vertical lines
          by gpo23
          i order a t-con because i had bad colors on my SONY KDL-40V3000 :
          With the new t-con the color are good but there are vertical lines on all the screen :
          I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
          Is there a way to fix the vertical lines on the new t-con ?
          Thank you for your help
          gpo23...
          10-04-2023, 09:11 AM
        • viking509
          vizio e65 e3 LED tv color vertical lines center tv only
          by viking509
          I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the...
          03-21-2023, 12:48 AM
