Samsung plasma TV PN51E550D1FX power cylcling
  • Sryii
    • May 2014
    • 22
    Re: Samsung plasma TV PN51E550D1FX power cylcling
    Thanks for the help Tom! You're the best and it seems like you spend a lot of time helping out people here. You don't happen to have like a digital tip jar or something so I could get you a cup of coffee and a bearclaw?
      You can put a few bucks to the service manuals site hosting, in my signature.
      I am not sure if Topcat accepts donations, but maybe ask him, as I (nor anyone else) couldn't help anyone here without badcaps.net. There is no tech forum as good as this anywhere else, I have looked!
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • CDNBrewer
        Samsung Plasma PN43D450A2D No Power
        by CDNBrewer
        Hello, I have a Samsung Plasma TV - Model # PN43D450A2D
        This was my parents TV and the initial symptoms were that the display was hard to turn on with the display making various clicking noises until one day it would not turn on anymore.
        I took a look and found a couple 1000uF capacitors (i believe on the low voltage size) that had leaked out their electrolyte and did not test well on a tester. I replaced them but still no dice.
        When the TV is plugged in, there is no clicking, LED status lights (on PCB boards or the front display) and the power on button...
        03-02-2025, 04:59 PM
      • mrtek
        Samsung UN43NU6950FXZA No power
        by mrtek
        Hi
        Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
        Main fuse = OK
        Back light LED = OK. Power them with aux power source
        LED output = OK 156V
        I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
        Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
        07-20-2025, 08:06 PM
      • karthur
        Samsung Plasma PN59D550C1FXZA Doesn't Power ON
        by karthur
        I picked this up at a yard sale and the owner knew nothing about it. Just knew that it didn't work. I get it home and sure enough it doesn't come on. Here is what I do see/hear.
        When its first plugged in, I can hear a click. It sounds like its from the power board. There is a red light on the front by the control panel that blinks 6 times. When I touch one any of the buttons on the front panel the red light will flash. I pulled off the back cover and looked at all the board. Nothing out of the ordinary. Nothing looks burned or damaged. On the power board (BN44-00445A), there...
        11-30-2024, 01:33 PM
      • Journey11
        Samsung TV won't turn on ... keeps cycling the power relay on & off
        by Journey11
        Hi All,
        First time posting here ... my name is Kevin but my friends call me Journey.
        I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
        After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
        It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
        07-04-2024, 02:44 PM
