Hey all!
I got this panel in a non working state, it was 4 2200uf 10v caps and 1 1500uf 35v cap.
I replaced the 4 2200uf caps with 25V of the same uf and the panel came right on. I didn't change the 1500uf as it was an odd ball uf and I didn't have it. I was going to replace it with a 2200uf 35v but I ran out of those too.
I put in a order and will replace the 1500uf as soon as it comes in.
Anyway the panel came right on after those were replaced, when the tv was on the back lights were only on in a low illumination mode with no input as soon as there is a signal the back lights illuminate brighter.
At the top of the screen as you will see in the photo below there are 5 half rectangle shaped anomalies at the top of the panel. They to me look like backlight bleed but once the panel warms up after about 5-10 min they are 95% gone and all you can see at that point on white/lighter screens are very light shaded in the affected areas the picture looks great and it doesn't seem to be affected to much when these are visible when first turned on..
What causes this to happen? I also see this on a few Vizio LG LCD models.
Is this a bad panel or tab bond issues?
