Philips 50PUS7363/12 Backlight but no picture
This topic has been answered.
  • groomit
    • May 2023
    • 29
    I'm having trouble with above mentioned TV. Bought it defect.
    Picture was heavily compressed around the horizontal axis. Fiddeled and tried different things (mask clock lines, swap T-Con). But no difference.
    Then I identified a heating capacitor on the left hand Signal-PCB (?) below the display. Replaced it by hand soldering. Checked for shorts afterwards. But now the screen stays black.
    I can see backlight, but screen stays black.
    What I've tried:
    - Disconnect right side cable from T-Con -> same (backlight but no pic)
    - Disconnect left side cable from T-Con -> I can see vertical stripes (spanning from top to bottom) near the center of the screen. First one white about 5 cm wide. Then two red'ish stripes. Finally the right half of the screen turns white.
    - Tried a different T-Con -> Same behavior
    - checked Caps on the left LCD-Connect-PCB for shorts (Small PCB below the screen which distributes the signal to the panel)
    Not sure the behavior of the right side is healthy. But definitely the left side seems to have some issues.
    Any hints on how to proceed?
  • Answer selected by groomit at 11-23-2024, 06:50 AM.
    lotas
    • Jan 2016
    • 4597
    • Russia
    Yes, I mixed up the number, remove these D004 from both sides, install resistors and that’s it.
    • lotas
      • Jan 2016
      • 4597
      • Russia
      Take a high-quality photo of these planks.
      • groomit
        • May 2023
        • 29
        Sure. Not sure what is important to see. I can do more and closer pictures if needed.
        Took a picture of the whole PCB left and right (looking from the back). And there are two closer ones each showing one half of the suspect side.
        • lotas
          • Jan 2016
          • 4597
          • Russia
          Here is this section, close-up and also the second plank.
          • groomit
            • May 2023
            • 29
            Thanks for taking the time. Here the requested pictures. The diode packs read 4267H. Not sure how to measure them correctly. Found some Infos on the forum and will try to follow.
            • lotas
              • Jan 2016
              • 4597
              • Russia
              Check the resistance on these 4 pins of each assembly relative to ground and the resistors (one resistor is not original and is installed incorrectly, it should be 101 (100 Ohm), but yours is 100 (10 Ohm)​
              • groomit
                • May 2023
                • 29
                I measured all 4 diode packs to ground. All come out open line or in the mega-ohms. Except for 1-2 lines which measure around 4-5k on both pcbs.
                Good spot on R075 - this is really bad (o.l.). It should be 100 ohm, right?
                Regarding R086 - you found my "work". Now that I see it again (1.5 years after initial try) I'm not quite sure I replaced the small cap nearby or the resistor. Doesn't make sense to replace a warm resistor.
                You're sure about the value (100 ohms)? My reference was the other PCB which I considered mirrored. There is a 10 ohm resistor installed.
                • lotas
                  • Jan 2016
                  • 4597
                  • Russia
                  Well, you can see from the photo that R075 is 101 (101 = 100 Ohm), R068 should be the same. Mostly the assemblies that burn here are D004.
                  • groomit
                    • May 2023
                    • 29
                    Thank you for the explanation. I see you do have practical experience with this TV/PCB - glad you found my request :-).
                    Just to be sure: By R068 - do you mean my replaced resistor R086? Do you think by adding the wrong value I fried something?
                    I will have a more detailed look on D004 and report back
                    • lotas
                      • Jan 2016
                      • 4597
                      • Russia
                      • groomit
                        • May 2023
                        • 29
                        Will do.Is it save to use hot air? Not sure how to attack D004 otherwise.
                        I'm concerned about the glued ribbon nearby
                        • lotas
                          • Jan 2016
                          • 4597
                          • Russia
                          Yes, be careful, do not damage this tape, the air flow should be low, you can stick foil on the tape and direct the flow of hot air against this tape, the board is thin, the components can be easily removed, you don’t need to overheat, you can drop flux on them and heat them up with a regular soldering iron from above and move to the side...
                          • groomit
                            • May 2023
                            • 29
                            First intermediate update: by just replacing R075 and R086 I made two observations:
                            - Plugging both PCBs into T-Con resulted in black screen as before
                            - Plugging the left one only resulted in holy smoke from R075.
                            I assuume this is related to the old and defective D004 parts on both PCBs?
                            Will proceed with removing the D004s and the again defective R075.
                            Is it possible to test the tv with these D004 removed?
                            • lotas
                              • Jan 2016
                              • 4597
                              • Russia
                              Yes you can, I never put them back and it works for years...
                              • groomit
                                • May 2023
                                • 29
                                @lotas: You Are. Genius.
                                Thank you soo much for your responsive and helpful attitude.
                                I almost scrapped the TV and you helped me fix it with parts worth cents!
                                • Davidhames
                                  KDL-70R550A Peeled off LCD Tabs on left side and perfect picture for 5 minutes
                                  by Davidhames
                                  Hi Guys,
                                  Thought I might try and seek advice on an issue I am having, I got this SONY tv for free that was having some dark greenish colouring, I replaced the T-CON and too my suprise the TV would not boot - I would get 5 blinking red LED lights. I dug deeper into this forum and someone mentioned the fact that it might be the tabs that connect to the LDC panel, and peeling them off should bring back a clear image. I tried this on the side of the T-con that was causing the tv to not boot when plugged in (left) and wow a perfect picture and was booting up fine! All was well and good...
                                  02-23-2022, 08:21 PM
                                • howardc64
                                  Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                  by howardc64
                                  • Prior owner tried a replacement main board. No difference.
                                  • Samsung 2x red blinking standby LED = panel fault
                                  • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                  • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                  • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                  07-19-2025, 10:54 PM
                                • Fly_Among_Stars
                                  VIZIO E70-E3 Half picture with half TCON
                                  by Fly_Among_Stars
                                  I have a VIZIO E70-E3.
                                  Symptoms: Black screen, no picture, but LED backlights are working.
                                  I probed the power board and voltages are as listed on the board.
                                  Main board appears fine, too.
                                  I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                                  There are two separate ribbon cables feeding the LCD.
                                  If both are connected, the screen is black.
                                  If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                                  04-24-2023, 08:20 PM
                                • Tr0ll
                                  by Tr0ll
                                  Original T-con:
                                  First replacement T-con:
                                  10-07-2023, 07:48 PM
                                • halen
                                  Hisense H55U7B vertical stripes
                                  by halen
                                  I have Hisense H55U7B TV with no picture, only big vertical stripes. I did several tests and I'm not sure, where is problem.
                                  1. Connected tcon to 12V, white, red, green, blue, black picture visible in cycle on full LCD without error
                                  2. Connected only left side of LCD to tcon, big stripes
                                  3. Connected only right side of tcon, visible normal picture on the right. Working as expected.
                                  Where could be problem?
                                  Tcon RSAG7.820.7932/ROH
                                  Main board RSAG7.820.8698/ROH
                                  Jan
                                  06-18-2025, 03:58 AM
