LG 32LC56-ZC 2 sec to black, and Standby--sorta....
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    This set is rather an odd Backlight/going to stby fault....
    From Stby, turn set on. Will start up, show picture then within a few seconds, (2-6 secs) of turning on, the backlight will either blink once or twice or just blank out--backlight off, then go to standby, within half a second or less.
    The 'ERR-OUT' voltage is constant at 1.8v, except when the backlight is off or blinks. disconnecting this wire from the MB doesnt affect the fault in any way.
    Turn on again, will repeat. Its one of these combined PSU/Backlight types, and Ive confirmed the PSU is working and the backlight is good along with the PSU part that runs it by making 'Inv-C' and PS-ON 3V from the STBY 5V via resistor.
    ERR-OUT stays constant 1.8V during this test.
    Had backlight running for about half hour no probs at all. The MB was disconnected during this run/test.
    It appears the Mainboard is turning the backlight off intermittently then it goes to standby.
    Any ideas?
    TELEFIX
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: LG 32LC56-ZC 2 sec to black, and Standby--sorta....
    After some research--seems like there's issues with this series of mainboards. Here is a SVC that indicates some inductors that can cause this and various other faults--
    http://www.tv.quuq.org/forum/index.p....0;attach=1251
    However, It didnt help in my case....
    There's also a series of caps on the mainboard--that cause a variety of picture faults...
    --a kit with the circuit ref numbers here--
    http://www.ohmsupplies.co.uk/REPAIR-...4040-LG-32LC56
    Again--This didnt fix my fault however!
    TELEFIX
    • audiofreak19
      • Apr 2013
      • 556
      • usa
      It sounds like there might be a ccfl bulb bad. Those symptoms are very common for that fault. Test it by taking panel out and turn on to see if all the bulbs fire up at same brightness
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        Aye--you would have thought so--But I can get the BL to run faultlessly by 'Potching' the PSU/BL board. (PS-On and INV-C to +3V)
        The BL in this set I Think is a single tube, wound back/fourth down the screen zig-zag style--bit like a fridge condenser-coil--, there's only two connections to the backlight tube, and a single HV transformer on the PSU board...
        Wiring a std. 20W CCFL energy-saver domestic bulb (Stripped of its internal electronics, so just the tube) to the transformer, will flash brightly very briefly twice, then thats it.
        Wiring the same CCFL in series with the original BL, and the fault is identical to without it,--ie no change, although the additional CCFL bulb lights at the same time as the BL, and at normal brightness.
        I did find a thread on another forum going on about firmware, and potching the set to force it to stay on, similar to above but with MB connected. Might try that, but very dubious on that thread's contents about 'one firmware fits all' so-called-- advice, so wont be messing with the F/W.....
        TELEFIX
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          Well--It gets stranger and odder!
          I got hold of another 32LC56-ZC today--What Luck!
          This one was dead. No LED, No life--nothing. Examination showed that four 2200uF 10V caps to be rather sad.
          I grabbed the PSU out of the first set above fitted it and with confidence--fired it up.
          --Or rather--Not!
          Exactly the same fault as the first set. It would start up, show a picture for a second or so, then back to standby.
          Oh dear!
          I decided to repair this second sets PSU and replaced these bloated caps--with some 3300uF 10V Panasonic as these were all I had of the same physical size.
          Fitted this back in the second set--which then fired up normally and ran until I pulled the plug.
          I removed its PSU and fitted it to the first set--Which also worked faultlessly.
          So the fault is PSU based--Even though I can get the PSU to run faultlessly on its own by making PS-On 3V and Inv.C 3V, it will supply all the voltages correctly and run the backlights, with no flickering or blinking of the BL.
          All electrolytics have been replaced with good quality, low ESR ones--Although there was nothing wrong with the originals.
          I decided to swap over the HV CCFL Transformers--even though the boards are just slightly different, one from set 2 being a V1.1 the other, the faulty one being V1.3 the transformers test and look identical.
          The fault stays with the faulty V1.3 board. So--Its not that transformer....
          I dunno--Strange one.... All I can say for certain--It Aint The Mainboard.
          TELEFIX
          • Alastair E
            Chief Womble
            • Mar 2013
            • 1963
            • U.K.
            Right-- a bit more work done.
            There is a pin of the PSU marked, ERR. Guessing 'error'
            This with the good, working PSU sits at 4.9V.
            With the bad PSU during the time the set is active before standby is sitting at 2.09v
            Removing the wire from the plug at the PSU and attaching this lead to a 3.7V polymer batt, the set will run normally and not go to standby.
            So--Chicken/egg. Is there a fault somewhere--Or is the error circuit at fault! I dunno, cant find a diagram for this EAY38639701 PSU anywhere.....
            TELEFIX
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Update ?
              • Alastair E
                Chief Womble
                • Mar 2013
                • 1963
                • U.K.
                Ha--I botched it!
                Wired the err pin to the 5v rail. Set is still running fine however--2 years later...
                TELEFIX
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Sweet
                  • HTR-Informatique
                    by HTR-Informatique
                    02-09-2025, 06:51 AM
                  • turmix
                    AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                    by turmix
                    Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                    The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                    At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                    During another reassembly, I made a mistake, and...
                    01-29-2024, 03:48 AM
                  • Mgiffune
                    by Mgiffune
                    06-09-2024, 10:28 AM
                  • Audeze
                    Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                    by Audeze
                    I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                    Does...
                    10-06-2024, 08:54 PM
                  • howardc64
                    Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                    by howardc64
                    • Prior owner tried a replacement main board. No difference.
                    • Samsung 2x red blinking standby LED = panel fault
                    • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                    • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                    • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                    07-19-2025, 10:54 PM
