LG plasma 42pt350 relay just clicking.
  • dkneyle
    • Dec 2013
    • 445
    Re: LG plasma 42pt350 relay just clicking.
    STR W6053s is a packaged regulator. It wasn't the device I was thinking of necessarily, but I don't have a circuit diagram so I'm just going from my knowledge of how these SMPS usually work. The power MOSFET are three terminal devices mounted on the heatsink. Usually there will be about four of them.
    Is the diode that was failed connected to the STR W6053s? (Trace the tracks and see if it is.) If so, then I'd reckon this device is U/S. With your diode function, measure across pin 1 and 3 of the STR W6053s. If it appears to be dead short you know for sure it's cactus. It has a FET drain and source sitting across these two pins. If you see some resistance or voltage drop on diode function then it might not have failed.
    If you look on E-Bay you can pick these devices up for just a few bucks. Given your symptoms it is worh taking the gamble and changing it over.
    Maintain the faith - should be an easy fix to get this one going again!
    • beetle1303
      Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
      by beetle1303
      I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
      On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
      01-13-2025, 08:49 PM
    • CoinCoin88
      Garage door RX unit (Cardin S38C) does not short relay to send opening signal
      by CoinCoin88
      I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
      Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
      09-15-2025, 03:36 AM
    • DodgyTech
      60" LG 60PB690V relay clicking issue
      by DodgyTech
      I require some help with my TV. The TV standby light blicks on and off with a clicking sound (relay?) from the back. After I opened up the TV, I set about troubleshooting by unplugging the boards to try and isolate the problem. My troubleshooting suggests that the logic board is causing the issue, but it could entirely be the YSUS board which is only activated once the logic board is connected.
      I have recorded a video which I thought would be an easier way to explain the problem and show the boards at the same time.
      I would like to try and identify...
      07-07-2023, 10:30 AM
    • GraphicMan
      Pioneer amplifier A-205 Relay not clicking after a mistake i made
      by GraphicMan
      Hello guys
      Because the unit is old (but only occasionally used) the loudness button causes some noise due to bad contact,
      sprays did not work, so i decided to solder the pins that it connects on the pcb at the on (loudness on) position
      i did that and it worked fine, i know from the bottom of my heart that the switch connects 2 pins and also d/c other 2 pins
      on every position it have (6 pin switch), so i was curious what would happen if i clicked the switch off while the pins are soldered at on (so basiclly on and off at the same time), when i did so the sound is gone, nothing...
      05-05-2024, 06:20 AM
    • Sisko
      Onkyo-593 No power and now clicking sound
      by Sisko
      Hi all!!
      Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
      10-03-2025, 02:18 PM
