Samsung eu75nu8000 no picture after tape method
  • PNI E.
    • Nov 2024
    • 101
    • Italy
    Hi guys, I write here for help me. I have a Samsung eu75nu8000. The Tv start to turn off and on, and I understand it was a panel problem, because if I take out a ribbon the Tv stay on. I tried the tape method but I have no picture but the Tv now stay on. My question is I have to give up because it s the panel? I notice that the chip vpm2sm it s really really hot, I can’t stay with my finger on it. Do u think all the problem of my panel is due to this chip, or u think it s a death panel and I can’t do nothing?sorry for my English
  • Diah
    • Feb 2013
    • 6550
    vpm2sm are DC to DC converter.. mean the output circuit it feed had short.
    • PNI E.
      • Nov 2024
      • 101
      • Italy
      So I can’t fix it if with the tape method doesn’t work and the screen is all black?
      • Diah
        • Feb 2013
        • 6550
        you need to find out the short, its about caps or essd diode on panel buffer boards if not at gate way transistor inside the screen glass, or also some one play with set before you and did damage the LVDS cable between MB and Panel.
        • PNI E.
          • Nov 2024
          • 101
          • Italy
          So the chip is getting hot because a short after him, I have to find the short on the panel buffer. If there I can fix, but if the short is inside the screen glasses transistor I can’t fix right?
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4535
            • Italy - Milan
            ue75nu8000... the right code
            post a photo where it's visible where is that hot chip.. i guess it's not the panel..
            post also a photo of the entire back view with the boards..
            if there is a separate tcon, and the tcon "processor" is of BGA type, try by yourself or with someone help to keep pressed that BGA, then turn on TV and see if image appears.. better to do it after you freezed that chip / board..
            • PNI E.
              • Nov 2024
              • 101
              • Italy
              Thanks for the answer, I’m from Rome, I see you are from Milan. The Tv model eu75nu8000txzt. The chip that become hot is vpmwsm, I show u the board, tell me what I need do and I do….i signed in yellow circle the chip that become hot. Tell me what I need to do. If u want I can write u in Italian
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4535
                • Italy - Milan
                Hi, the model starts with UE, not EU.. well, the chip you marked is the PMIC that controls the various power rails to the panel, i'm surprised in a 75 inches there is no separated TCon, shame on Samsung, disgusting.. now the first thing you have to do is to remove the metal.plate bars on the bottom that hides the panel strip boards, on those boards you have to check every bigger capacitor for short circuit, there are also very small diodes or diode packs, if there is no short neighter on them, then locate an eventual U shaped junction flat cable, detache it one side, then plug the power cord and see if the boot loop stops and maybe searching between TV stations you hear the sounds..
                • PNI E.
                  • Nov 2024
                  • 101
                  • Italy
                  I’m back guys, I know I’m your nightmare but I really want try to fix my Tv. So here my test. The Tv do NOT turn on with both the flat cable in. Do not turn on also if I plug off the U flat on the little boards on display. If I plug off one of the flat cable from the main board to the display, then the Tv turn on with sound backlight on but no images. The thing I don’t understand the Tv turn on if I plug off the right side panel flat, but works also if I do the opposite, if I plug off the left flat panel and plug on the right the Tv start on, so don’t care with flat cable I take off, the Tv with just one flat right or left plug in turn on with sound and back light on but no image. I notice if I plug the right flat panel the chip vpm2 is more hot.
                  davi.p I did what u asked me and I test all the capacitor on the little board on the bottom of display. I put the tester in beep mode and I had some capacitor that sign in short, I make the photo. The capacitor beep have a resistence of 2,5 ohm I don’t know if it s normal…If someone can help me it will make me really happy. I give u the photo of the test of capacitors so if someone tell me what to do I follow.
                  davi p are u Italian?
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4535
                    • Italy - Milan
                    Those 0,9ohm caps sounds a bit strange, maybe is a misread.. have you tested with main board detached from panel? What could be do is to locate on the main board the two common test points that when connected together disables the protection, so you can test the voltage on the TCON part of the main board, but most of all on the panel caps... i think i know where we will end, i tell you what i think i discovered, the reason why no matter which ribbon you detach the tv stays on is that it is not the panel at fault but the main board.. by detaching half panel you unload a certain amount from the main processor (well.. the only processor) that is heavily oxydated.. so if you want to try this test., but i don't know if is effective, you can freeze the CPU or the entire board, then turn on the TV pressing the chip and asking someone to watch the screen...
                    PS: Sono italiano mi chiamo Davide..
                    • PNI E.
                      • Nov 2024
                      • 101
                      • Italy
                      The capacitor I tested with the flat plug in, if I unplug the flat cable I don’t have more beep from the tester on the capacitor. So u are saying me to try to freeze with the cold spry the cpu ( I call cpu the main processor ) then press on it and turn on the Tv. If I have for some second the video, it means the panel is ok and it s a main board problem. Am I saying all correct.
                      • PNI E.
                        • Nov 2024
                        • 101
                        • Italy
                        I freeze the cpu and press it and try if I see the video I give u the photo of the cpu, and where are the point I have to connect
                        ps ciao Davide sono Fabrizio grazie per l aiuto
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4535
                          • Italy - Milan
                          I cannot locate the two test points, the board markings are not readable, do as follow, use multimeter in continuity, check between the 2 most inner pins of the connectors for the flat cables that goes to panel, if them are connected, check also between the outmost pins (with the panel inserted), if are connected, then you can try connecting a very slim wire between these last two, so you can check the panel tensions... ok but.. these tests are not mandatory, because you already confirmed you have no shorts in panel boards... the real test is the one on the cpu, i confirm you have understood it..
                          • PNI E.
                            • Nov 2024
                            • 101
                            • Italy
                            Come back after the test that suggest Davi.p. I freeze the processor, the Tv start but after 4 5 sec turn off. Always backlight on and sound, display without picture all black no strips nothing, just black. What I notice is if I put a finger on the cpu a part become very hot, hot that u can barely have finger on it, I don’t know if it s normal. I show up the part that become hot. Do you think it s a main board faulty? I have hot air gun can I try to remove the cpu, but I never done,,,,if I remove and try to resolding do I think I can fix or I have to try to buy a new one
                            • Diah
                              • Feb 2013
                              • 6550
                              FB_TRDY 1 and FB_TRDY 3 are feedback points... search after them on yours MB close to LVDS socket
                              • PNI E.
                                • Nov 2024
                                • 101
                                • Italy
                                Thanks for your help, when I find this point what I should do…sorry I’m not a professional, but if u say me what I have mesaure I can do it, thanks
                                • Diah
                                  • Feb 2013
                                  • 6550
                                  normally we jumper this 2 points together.. so the MB will learn there are panel connected... so you can disconnect one LVDS at time or also one U ribbon.... to check picture how it look to know which side defect.... but i have doubt too you will see any picture because you have short make the IC very hot to touch. give try
                                  • PNI E.
                                    • Nov 2024
                                    • 101
                                    • Italy
                                    Really thanks I give a try and let you know, but at this point I think it s the cpu in short not the panel, there is a way to test the cpu?
                                    • Diah
                                      • Feb 2013
                                      • 6550
                                      dont touch the Soc right now,,,, to know if the short at the MB... disconnect the 2 LVDS from MB side and turn on... check the IC temperature
                                      by the way why you removed the heat sink of it ?
                                      • PNI E.
                                        • Nov 2024
                                        • 101
                                        • Italy
                                        I follow what Davi.p said me. He said me to freeze it with the ice spray, and press it and turn on and try if I had video, but unlucky I didn’t have nothing, I mean the Tv turn on 5 sec with audio, backlights on but screen all black. And I notice the cpu hot, and the freeze there gone very very fast. But I didn’t try without the lvds disconnected….i try and say u.
                                          09-07-2024, 05:50 AM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • YellowJacket
                                          Samsung QE55Q60RAT - no picture
                                          by YellowJacket
                                          Hi friends,
                                          a friend of mine gave me this TV to fix, with common SAMSUNG TV issue - damaged panel. Turning on, sound is present, but no picture. So I went directly to standard process, connecting two pads together with a wire ( see in the picture ), and then removing flex cables. With right flex connected, there was half screen working, but still no picture ( disappearing colors and similar weird stuff ) + working sound. With left flex connected, TV is restarting + working sound. I supposed, left side is damaged, so I then blocked all 8 CLK pins ( going from 0R resistors on the second...
                                          07-30-2024, 01:31 PM
                                        • howardc64
                                          Best method to remove Samsung screwless rear panel
                                          by howardc64
                                          I've done a few of these. Using Samsung Service Manul method always result in some broken bits and the snap lock metal wire always gets bent and not reinstall as nice as original. After reinstall often have some pops and clicks. This is the best method I found so far. Pull the wire out instead
                                          https://youtu.be/paYZAc1rcWs?si=GHdTOv5ySIJgjZOC&t=82
                                          Here is a pic of how the hook on the wire locks
                                          Stil ended up with a couple of small broken bits on the bottom haha. But the wire stayed perfectly straight and seems easier/less forceful. Fishing...
                                          10-12-2025, 07:52 PM
                                        • Yanleb
                                          Samsung UN58TU7000F no picture
                                          by Yanleb
                                          I have a Samsung UN58TU7000FXZC (same as UN58TU7000FXZA, just the Canadian model) with no picture. Backlight is on and sound is coming out just fine. Just no picture.
                                          What is frustrating is that there's no voltage test point and no component labelling of any kind.
                                          What I have found so far:
                                          1. No voltage at pins 91-94 of the 96 pins connector CN1300 (marked 1 on the picture). This TV set has no T-CON board. The 96 pin flex cable goes directly to the right (when facing TV) lower panel board. Itself is linked with another flex to the other side.
                                          2. Voltage...
                                          01-19-2023, 01:44 AM
