I am seeing that the ICs are faulty on these boards (3407F). But how to test them? These boards are found in Samsung 50' plasma TV sets.
Testing a Buffer Board LJ41-05121A
Re: Testing a Buffer Board LJ41-05121A
Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails DeveloperComment
Hi there, Got the buffer boards and Y-MAIN board from Samsung 50" HD
LJ41-05120A
R1.3
Buffers LJ-05121A & 22A with R1.0
Fluke 115 set to diode RED to input between 1-24 and BLACK along OP's with no continuous bleep? at least one obvious totally blown IC U5401 on board 121A and obvious damage to Y-MAIN with blown caps, one cap so bad i could not ID it but board REF is C5817 if anyone can ID it. next obvious is C5807.
Im no pro, started trying to ment a small 22" for my daughter, friend mentioned his went off with a bit of smoke and a quote to repair, offered to help as best i could.. but really want to make sure i can replace all faults before purchasing any components etc. hope all pictures help.Comment
Buffers will require lots of practice to remove and replace without damaging the board. Also a hot air station will likely be required. I am not familiar with the common mode for failure of this ysus, but a repair kit lists Q5500, Q5501, Q5302, Q5303, Q5304, Q5306, as well as 2 surface mount resistors, 3 capacitors, 1 zener diode, buffer chip is IC 3407F. However that cap that is blown to pieces is not one of the common ones to fail so your board is likely in worse shape than the normal failureLiberating magic smoke one part at a timeComment
LJ41-05120A
R1.3
thanks, i had thought the same in relation to the damage, as it's not the common failure.
paulComment
Yeah, pretty nasty isn't it, this was my first thought when i seen the buffer IC that it has probably burned through the tracks on the board.. very unfortunate has been quite a failure to cause that damage to the boards, so put it down to a write off lol.
thanksComment
Assuming...7 Photos -
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by repair-itI am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... - Loading...
