Testing a Buffer Board LJ41-05121A
  • speedypro
    • Feb 2013
    • 561
    • United Kingdom
    I am seeing that the ICs are faulty on these boards (3407F). But how to test them? These boards are found in Samsung 50' plasma TV sets.
    Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
  • Caleb
    Smokin IC's
    • Feb 2013
    • 645
    Re: Testing a Buffer Board LJ41-05121A
    youtube on testing these
    Liberating magic smoke one part at a time
    • speedypro
      • Feb 2013
      • 561
      • United Kingdom
      Thanks! Found two ICs on my buffer board at fault
      • tw2005
        • Oct 2011
        • 6458
        https://www.badcaps.net/forum/attach...7&d=1400500489
        • speedypro
          • Feb 2013
          • 561
          • United Kingdom
          • tw2005
            • Oct 2011
            • 6458
            • st.jimmy05
              • May 2015
              • 17
              • united kingdom
              Hi there, Got the buffer boards and Y-MAIN board from Samsung 50" HD
              LJ41-05120A
              R1.3
              Buffers LJ-05121A & 22A with R1.0
              Fluke 115 set to diode RED to input between 1-24 and BLACK along OP's with no continuous bleep? at least one obvious totally blown IC U5401 on board 121A and obvious damage to Y-MAIN with blown caps, one cap so bad i could not ID it but board REF is C5817 if anyone can ID it. next obvious is C5807.
              Im no pro, started trying to ment a small 22" for my daughter, friend mentioned his went off with a bit of smoke and a quote to repair, offered to help as best i could.. but really want to make sure i can replace all faults before purchasing any components etc. hope all pictures help.
              • Caleb
                Smokin IC's
                • Feb 2013
                • 645
                Buffers will require lots of practice to remove and replace without damaging the board. Also a hot air station will likely be required. I am not familiar with the common mode for failure of this ysus, but a repair kit lists Q5500, Q5501, Q5302, Q5303, Q5304, Q5306, as well as 2 surface mount resistors, 3 capacitors, 1 zener diode, buffer chip is IC 3407F. However that cap that is blown to pieces is not one of the common ones to fail so your board is likely in worse shape than the normal failure
                • tw2005
                  • Oct 2011
                  • 6458
                  LJ41-05120A
                  R1.3
                  that's pretty messed up ymain. you may have trouble with that buffer looking at that burn. I've got one like that and it's burnt through the board and tracks making it not repairable.
                  • st.jimmy05
                    • May 2015
                    • 17
                    • united kingdom
                    thanks, i had thought the same in relation to the damage, as it's not the common failure.
                    paul
                    • st.jimmy05
                      • May 2015
                      • 17
                      • united kingdom
                      Yeah, pretty nasty isn't it, this was my first thought when i seen the buffer IC that it has probably burned through the tracks on the board.. very unfortunate has been quite a failure to cause that damage to the boards, so put it down to a write off lol.
                      thanks
                      • howardc64
                        by howardc64
                        07-24-2025, 05:17 PM
                      • howardc64
                        by howardc64
                        Problem
                        08-04-2024, 10:36 PM
                      • m1ch43lzm
                        by m1ch43lzm
                        05-12-2025, 08:37 PM
                      • howardc64
                        Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                        by howardc64
                        • Prior owner tried a replacement main board. No difference.
                        • Samsung 2x red blinking standby LED = panel fault
                        • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                        • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                        • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                        07-19-2025, 10:54 PM
