Samsung UN85AU800DF
  • Jason616
    • Sep 2016
    • 99
    Back to this tv
    I got a led tester
    this is what I get
    Pins 1-3:145 volts
    Pins 5-6:149 volts
    Pins 8-9: 149 volts
    Pins 11-12: 28 volts
    if I did this correctly it looks like some of the led strips are shorted
    • EazyBone
      • Jun 2023
      • 1303
      • United states
      Yes appears that's correct. I would just recheck it a couple times, I've made user error doing this B4 but looks like it's shorted yes. Did you try a flashlight to the screen after plugging it in? Can you get the light now?
      • Jason616
        • Sep 2016
        • 99
        I believe the power supply board is working correctly but with the led strip being defective it shuts the power supply board down . So I’m going to replace the led strips and see if it works or troubleshoot it more
        • EazyBone
          • Jun 2023
          • 1303
          • United states
          Well good luck with that. Those screens are massive and not easy to move, hope you got 2 people and a lot of suctions!
          • Jason616
            • Sep 2016
            • 99
            Well I guess it got overlooked . Is there anyway around this ? One of the screen drivers failed and that’s why the person got rid of the tv . I remember another tv I had where 1 of the screen drivers blew and I cut the drivers off 1 side of the screen and the tv worked for a couple years . Is there away around this being bad or does it need a new panel ?
            • Storyteller12
              • Jun 2020
              • 624
              Unfortunately It’s trash. Needs a new panel
              • Asraf Atb
                Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                by Asraf Atb
                Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                01-27-2025, 05:02 PM
              • Dani_2024
                by Dani_2024
                10-28-2024, 05:06 PM
              • Lee M.
                Samsung UN75RU8000FXZA bad main board?
                by Lee M.
                When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
                11-08-2023, 07:46 PM
              • JDC
                by JDC
                ONN 100012588
                Long answer:
                07-15-2022, 07:39 AM
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
