I am getting 7 blink error on panasonic tv.The sc board seem to be problem i ordered repair kit from shopjimmy and did not fix my problem.I also jumpered sc test connector and turned tv see if board would give me a error gave me 7 blinks.I assume if board was good it should have not blinked.any help would be appreciated.
Tnpa5081 af 7 blink error trying to repair
Re: Tnpa5081 af 7 blink error trying to repair
Take a look at this thread Tw2005 is the master of the 5081Liberating magic smoke one part at a time -
That's because the dickheads have not included some key components which commonly fail more than some of the other bits they have put in.I am getting 7 blink error on panasonic tv.The sc board seem to be problem i ordered repair kit from shopjimmy and did not fix my problem.I also jumpered sc test connector and turned tv see if board would give me a error gave me 7 blinks.I assume if board was good it should have not blinked.any help would be appreciated.
I expect SJ will be getting regular complaints as they sell these kits. Of course the common out will be that the kit fixes most but if you go to my 5081 thread, just had a conversation with someone about no 30F125 IGBTs and the schmitt inverter which I can almost guarantee will be dead with all 5081 shorted SC2 failures.
Hopefully nothing has popped with your powerup attempt. Hopefully you can sort it or I cross paths online to help (fingers crossed)Last edited by tw2005; 05-15-2014, 04:12 PM.Comment
After reading your other post tw2005 30f125 igbts has i short and it took out Q661 and probably took out some other components.I will try to hook up my leakfinder see if i can figure out where my other shorts are at.still trying to figure out how to use it got it a few weeks ago.Comment
Q661 will most likely be due to the schmitt inverter IC, marked HA, 5 pin located near Q818 which could also be dead as well .After reading your other post tw2005 30f125 igbts has i short and it took out Q661 and probably took out some other components.I will try to hook up my leakfinder see if i can figure out where my other shorts are at.still trying to figure out how to use it got it a few weeks ago.Comment
Scmitt inverter and Q818 could definitely be a culprit as I found out after numerous failures with the board. From now on, on every board I will replace them, even if, especially Q818 looks innocent in cct. D702 was included in the kit, also read ok, but since it is connected directly to always shorted HA inverter, would be safe to replace it too
But, man, I'm still on cloud nine after fixing the board yesterdayComment
The inverter cct 100% is responsible for switching Q661 which drives that small transformer on the board. effectively if the IGBT is not pulsed, T471 presents it self as a dead short which it is and Q661 I suspect is switched on, not cycled on/off and bang.Scmitt inverter and Q818 could definitely be a culprit as I found out after numerous failures with the board. From now on, on every board I will replace them, even if, especially Q818 looks innocent in cct. D702 was included in the kit, also read ok, but since it is connected directly to always shorted HA inverter, would be safe to replace it too
I've already highlighted all the bits involved including the 5V reg in the other post. just a matter of being patient and thorough. I'd recheck all previous replaced parts too.Comment
I will replace those items and check see if anything else is shorted.As far as Shop jimmy kit i think they truthly believe there kit will fix the problem but like tw2005 pointed out they probably did not test the kit to make sure it would fix the problem.Or did not test enough boards to make sure it would work properly.I can not speak for every one but i contacted them and told them there kit did not work.There response was are u sure it is the sc board and not main board or sm board or panel they could also cause 7 blinks.I told them i was sure the sc was they problem.They immedaitely refunded my money.I hope they take your advise tw2005 and include the parts that are missing and do more testing.Because this could make a good kit if they would get it right and it is reasonably priced.Comment
I checked ic 771 and it is shorted out not sure about q701 and q702 them i checked them out there is no low resistance also i checked ic773 and pin 5 and 1 are showing .2 ohms i would assume this means ic is shorted.Comment
Yeah, I guess you never had a chance to read my thread through before you fitted the kit.
That being shorted is one reason why the kit failed, not included so that was short even before you worked on it, that is why Q661 is dead again.
Short should clear with IC773 removed, IC771 supplies it.
IC771 is that in the kit?Comment
so I guess your just waiting to source the inverter ic and 30F125 + the RJP63F3A.
Have you got any 2009/10 Samsung boards worth scrapping?
I know the 42C450 series have RJP63F3 transistors on the Ymain, could be some Toshiba too .Comment
by pixelcapPioneer Kuro Pro 111FD 8 blink red LED.
I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...1 Photo -
by Sus256Hi all!
HISENSE 65E7KQ PRO
RSAG7.820.13512 - chassis
MT9618BAATAB - cpu
RSAG7.820.12059 - power
HD650Y3U77 - panel
KLM8G1GETF - emmc
Replaced emmc.
Terminal log
UART
AC_ON
E-B
FDE enabled
layout pattern onebin by SAR7,0... -
by nervxYears ago my tv gave a 7 blink code which turned into 8 during diagnosis. I had ordered a replacement ss board but somehow the tv started working again and i never used the board. Now a week ago my tv flickered and shut off at random and gave the 8 blink error code. The same issue it had all those years ago. The only difference this time is that over the last few months there has been some purple and green tinge that comes and goes in more solid colors such as white.
Anyway i checked all the screws and replaced the ss board with a known good one and still got 8 blinks. I saw a... -
one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
We replaced the SCR with new device,, but the device is not power on as expected.
Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....09-26-2025, 09:00 AM -
by Superbee_dadHello Sharp TV experts
Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
> I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
> There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...01-24-2025, 11:51 PM - Loading...
