samsung ue32c5100 not power no stand by
  • hectorcrk
    • Sep 2013
    • 8
    • spain
    hello again
    my tv is not working, nopower , no standy, no led ,no image
    try to dissasembly and no bulb condensateur, fuses working fine
    how to resolve it , thanks
  • sordids999
    • May 2013
    • 2152
    Re: samsung ue32c5100 not power no stand by
    posting some pictures of the boards may help you
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      Check for bad joints, and post clear pictures of both sides of the board
      • hectorcrk
        • Sep 2013
        • 8
        • spain
        waitinng one hour and post images of power supply . thanks
        • hectorcrk
          • Sep 2013
          • 8
          • spain
          hello again , upload pictures. thanks
            OK, did the TV just stop working or was it hit by surges? Did any one else work on it before?
            You can start with by check the DC voltage right at the two legs of the two long caps laying on their side, just be careful not to touch anything with your hands or body.
            • hectorcrk
              • Sep 2013
              • 8
              • spain
              hello again
              budm thanks for aswer
              yes this tv led working fine , disconeect to the electrical power
              next day , plug in the electrical , power on , on not working it
              no other circuntances
              sorry for my bad english language
              thanks
                Diagram for BN44-00351B oiwer supply:
                http://www.toms-service-manuals.com/
                • sordids999
                  • May 2013
                  • 2152
                  Hi guys
                  im having the same problem totally dead,i have checked for cold solder joints and i have tried disconnecting the main board legend to see if i can get back lights but nothing
                  warmed up the power supply and main board but still nothing also no voltage from the PSU legend but main 450v caps are reading 334 volts
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Originally posted by sordids999
                    Hi guys
                    Checked secondary side for short circuits ?
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      What voltages are you getting on ICS801 (STR-W6052S)
                      • sordids999
                        • May 2013
                        • 2152
                        0.15 volts but slowly dropping
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          What pin is that on?
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            • sordids999
                              • May 2013
                              • 2152
                              i tested on all the pins
                                That can't be if you do have 330Vdc on the main cap unless the trace to the transformer TM801 pin 3 is open or winding on pin 1/3 is open which I doubt that very much.
                                What did you use for GND?
                                One thing I would do on that board is to resolder all the transformer legs, all the legs of the devices mounted on the heatsinks.
                                • sordids999
                                  • May 2013
                                  • 2152
                                  sorry my bad i hope this makes sense
                                  pin 1 10.89 volts
                                  pin 3 11.42 volts
                                  pin 4 11.43 volts
                                  pin 5 gnd
                                  pin 6 11.43 volts
                                  pin 7 318 volts
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    Pin 4 (VCC) needs to be a minimum of 13.8v to work.
                                    You need to check the components linked to it.
                                    ZDS801
                                    CS805
                                    RS802
                                    DS802/3
                                    to start with
                                      Leave the RED probe on pin 4 (VCC), Black probe on primary circuit GND (Negative leg of the main filter cap), then apply the AC to the board and see how high the DCV will rise up to.
                                      There are two caps and Zener diode on pin 4, so if the Voltage on pin 4 does not rise up to the start up Voltage then it may be bad startup cap, leaky Zener diode, or cap, or bad charge pump circuit inside the IC, see diagram for details.
                                        09-07-2024, 05:50 AM
                                      • DXseekerMO
                                        Samsung UN65NU6900FXZA Stand-by light on but voltages on PS indicate TV should be on
                                        by DXseekerMO
                                        Hello everyone!
                                        Tonight I picked up a Samsung UN65NU6900FXZA with a curious issue.
                                        Symptoms:
                                        1) Plug TV in to AC outlet, stand-by light illuminates briefly and goes out.
                                        2) TV does not appear to turn on
                                        3) Backlights do not illuminate, voltages associated with backlights on Power Supply are not present
                                        4) "Power on" terminal on Power Supply has 3.26v
                                        5) "A13V" terminals have 12.9v
                                        6) Stand-by test jumper on Power Supply has 12.9V
                                        7) Optical audio jack on Main Board illuminates
                                        8) With stand-by...
                                        06-09-2021, 12:19 AM
                                        09-06-2024, 11:40 PM
                                        09-06-2024, 08:40 PM
