Samsung HLT-4675 DLP Shutting Down..
  • mmartell
    • Oct 2013
    • 3189
    Re: Samsung HLT-4675 DLP Shutting Down..
    Originally posted by R_J
    Looks like the light tunnel heated up. I've never seen that happen, how long did you have it running before that happened. The only thing I can think of is that the color wheel glass itself must filter the intensity enough so the light tunnel does'nt get that hot?
    About 10 minutes maybe ?
    • R_J
      • 9556
      The only thing I can see is that the uv filter is part of the color wheel, I guess the uv from the lamp must have caused the heat. on a lot of dlp tvs the uv filter is seperate, mounted between the lamp and the color wheel.
      • mmartell
        • Oct 2013
        • 3189
        I guess there's no way to repair this type of damage without replacing the whole tunnel. Is there an adjustment that needs done even if I could get that part in place ? And what is it that's moved anyway ?
        • R_J
          • 9556
          That metal piece that is in the picture is the light tunnel, it could be ok, it is made up of 4 small pieces of mirror and it looks like it survived, maybe only the plastic around it needs replaceing. on some there is adjustment but its easily done, if the tunnel is missadjusted you will get a shadow on either one of the sides or top or bottom of screen.
          Don't take the light tunnel assembly apart if you don't have to. as long as the tunnel down the length is not collapsed its fine.
          This is a picture of the tunnel itself, it is mounted in the black assembly with the silver plate at the input end.
          • mmartell
            • Oct 2013
            • 3189
            How long is this piece ? It disappears inside the plastic shell and I can't judge how long it is or if its safe to pry at it. It is fused to the plastic where it melted and rehardened.
              09-07-2024, 05:50 AM
            • AJ847.63e
              BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
              by AJ847.63e
              Hi All.
              Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
              The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
              09-18-2023, 06:42 PM
              09-06-2024, 11:40 PM
              09-06-2024, 08:40 PM
