Samsung HLT-4675 DLP Shutting Down..
  • mmartell
    • Oct 2013
    • 3189
    Calling R J.. lol
    I tried GIVING this set away but alas the damn thing came back to me. Starts and runs fine for about 10-20 minutes then the lamp goes out and set tries a couple times to restart it then shuts down with three flashing lights.
    If I let it sit for a moment it fires back up but for a shorter period this time before shutting down again. Thought at first was the lamp so replaced that but same thing. Seems heat related but all caps look ok.
    How does one troubleshoot as to whether the DMD, colour wheel or ballast/ps is the issue (or lamp for that matter) ?
  • R_J
    • 9553
    Re: Samsung HLT-4675 DLP Shutting Down..
    I don't have that exact manual but all 3 leds flashing (Optic chassis may be defective)
    How is the picture before it shuts down?, usually if its the color wheel acting up the picture tint (phase) will change. especially the reds. I hav'nt seen too many intermittent ballasts, but it could happen.
    [been a long time since I've worked on these]
    The lamp could cause this, you would need to sub in a known good lamp.
    Same for the dmd, hard to determine if its intermittent without subing it out, put usually if it was bad you might see pixelization, or something like that before it goes out.
    You say you tried a different lamp, but is it new or used?
    One more thing to check are the connetions for the color wheel to the dmd board, I have seen those go bad, poor solder connections.
    There is not much information about these sets,
    • mmartell
      • Oct 2013
      • 3189
      It's a new replacement from eBay but it's, gulp, chinese or wherever these knockoffs come from. But I figure with the same symptoms it's *likely* not the lamp.
      I was thinking I could monitor a pin or two to see what voltage drops out when the lamp kicks off to determine where the fault lies but don't understand the nature of these beasts well enough to know where to probe. Is there a self-diagnosis in the set ? When I turn the set on again I could go into the Service Menu if need be...
      I will run it again tomorrow and check the pic as it fails and follow up then. Thanks.
      • R_J
        • 9553
        Does this set have a temp sensor on the top of the lamp? it looks like the picture and has 2 wires going to it, you could jumper it (short it out) and see if thats causing the problem, but that usually gives an over temp error.
        The ballast has 2 connectors, one has 2 large wires with high dc voltage (around 380vdc)
        and a low voltage control plug 3-5 small wires, there should be +5volts on one of the wires when the balast is on, if those voltages stay the same when the lamp goes out then it could be the ballast.
        If that control line turns off when the picture goes off then the dmd is telling it to shut off for some reason.
        If the color wheel stops giving a feedback pulse to the dmd it will think the wheel stoped and turn the lamp off.
        • mmartell
          • Oct 2013
          • 3189
          That's exactly the type of info I'm looking for.
          I messed with this a while ago. I know I've already shorted the door switch (door is missing!). Not sure about the temp sensor though I'm pretty sure I have it. Will take a look.
          • mmartell
            • Oct 2013
            • 3189
            Ok gave it a test run without probing any voltages or such and the lamp shuts off without any warning or video degradation. The audio plays on for maybe ten seconds then stops and the lamp attempts to strike a couple of times before I hear the colour wheel wind down and the set shut off.
            • mmartell
              • Oct 2013
              • 3189
              Actually the set doesn't shut down it goes into some sort of sleep mode with the three lights flashing. Pressing the power button initiates the shut down melody and actual power off.
              This time I noticed a humming that was audible about ten seconds before the lamp went out. Colour wheel maybe ?
              • mmartell
                • Oct 2013
                • 3189
                Nevermind, the symptoms seems so erratic I think it's why I tried to just give the damn thing away lol.
                I'm going to monitor the 5v line at the ballast to at least attempt to narrow it down.
                • R_J
                  • 9553
                  How was the picture before it quit, did the color/tint change, It could be the color wheel, I replaced one for a friend that was intermittent, I thought I could lube it (sometimes works) to get it going but it was the air bearing type, the problem with his was the flat ribbon that drives the 3 phase motor was brittle and cracked.
                  The flat ribbon drives the motor, the plug with individual wires is from the photo interupter (pulse/tach) for the color wheel.
                  • mmartell
                    • Oct 2013
                    • 3189
                    Didn't notice a change in the pic before it went out. I've taken out the color wheel and given it a spin and it spins freely but there is an audible sound I didn't expect to hear. Is that normal ?
                    I'm going to run the set with the wheel out of the engine (hope it doesn't explode ) just so I can see it in action.
                    • mmartell
                      • Oct 2013
                      • 3189
                      RIP rear dlp, may you dream in 3lcd or something blah blah...
                      I killed it. I ran it with the color wheel facing up waiting for it to fail so I could maybe rule out the color wheel but smoke began to rise from the light tube and by the time it was all over there were some melted pieces in there. Didn't realize the wheel itself provided some cooling effect from the lamp.
                      I will have a look later to check on the extent of the damage but this just lightens my load actually. Almost can't wait to haul it to the curb hehe.
                        • 31072
                        if i had space, i'd like to try an led conversion on a dlp projector - just for fun.
                        • mmartell
                          • Oct 2013
                          • 3189
                          As in an led lamp in place of the stock lamp ?
                            • 31072
                            as in RGB-LED inplace of the lamp & disc.
                            although you could just dump a high power led in and keep the disc.
                            big leds generate a lot of heat, so you would need to mount it on a heatsink - probably a p4 / athlon type one on it's side.
                            then duct the existing fan to blow through the sink.
                            this is THE place for info on anything you could class a "lightsource"!!!
                            http://www.candlepowerforums.com/
                            • R_J
                              • 9553
                              The color wheel does not provide any cooling, I'm not sure what smoked, I've seen them run with broken color wheels and not had any problems other than no color of course.
                              After the lamp there is a uv filter, then the color wheel, then the light tunnel (4 small mirrors aranged in a square (tunnel), then some lenses, mirrors etc.
                              Did you have a picture with the color wheel out?
                              • mmartell
                                • Oct 2013
                                • 3189
                                Well the whole assembly was out and facing backward with everything plugged in but I could see a pic as it reflected off the various surfaces behind the tv, yes.
                                It looked like whatever is just past the color wheel assembly was smoked. Will attempt a picture when I get home.
                                  • 31072
                                  you wont get all that in the cheap no-name ones on ebay.
                                  i stripped one.
                                  starting at the rear:
                                  mirror
                                  lamp
                                  lense
                                  disc&lcd assembly
                                  space (for air to pass across from a side-fan)
                                  final output lense.
                                  i'v also stripped a newer one that was the same - but colour display & no disc.
                                  • mmartell
                                    • Oct 2013
                                    • 3189
                                    And evidence of the carnage... first one is top-down second one is straight on with lamp assembly removed.
                                    • R_J
                                      • 9553
                                      Looks like the light tunnel heated up. I've never seen that happen, how long did you have it running before that happened. The only thing I can think of is that the color wheel glass itself must filter the intensity enough so the light tunnel does'nt get that hot?
                                      • R_J
                                        • 9553
                                        i stripped one.
                                        mirror
                                        lamp
                                        lense
                                        disc&lcd assembly
                                        final output lense.
                                        I have no idea what this is about? I was just saying what components were after the lamp in the light path.
                                          09-07-2024, 05:50 AM
                                        • AJ847.63e
                                          BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
                                          by AJ847.63e
                                          Hi All.
                                          Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
                                          The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
                                          09-18-2023, 06:42 PM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
