Lg 42pj350
  • sordids999
    • May 2013
    • 2161
    Lg 42pj350
    ok so my latest project got this today it clicks when you turn the tv on then on the bottom of the screen you have distorted image then the tv will restart and do the same images again
    ive attached a video for you too see
    https://www.youtube.com/watch?v=kbz0nbQn9II
    thanks
  • tw2005
    • Oct 2011
    • 6458
    Re: Lg 42pj350
    That's incredibly uncanny.
    Look at this.
    https://www.badcaps.net/forum/showthread.php?t=37411
      Re: Lg 42pj350
      two 22R resistors topright of PSU usually.
      • sordids999
        • May 2013
        • 2161
        Re: Lg 42pj350
        5W22ROJ any idea on the part where to get some ?
        thanks
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          Re: Lg 42pj350
          22ohm, 5W wirewound resistor--A standard part, any competent parts supplier will have 'em....
          TELEFIX
          • vinceroger69
            • Mar 2012
            • 6714
            Re: Lg 42pj350
            thanks
            http://www.ebay.co.uk/itm/22-Ohm-5-W...item1e83bf1433
            or try cpc
            • sordids999
              • May 2013
              • 2161
              Re: Lg 42pj350
              • sordids999
                • May 2013
                • 2161
                Re: Lg 42pj350
                Update:
                1. I removed the Z-SUS board and found that the high power copper inductor had cracked solder joints
                2.Replaced the resistors
                working ok at the present moment just testing it now
                • tw2005
                  • Oct 2011
                  • 6458
                  Re: Lg 42pj350
                  Update:
                  Double whammy. So what did you think of the post I linked? perfect timing having that one solved just before yours.
                  • sordids999
                    • May 2013
                    • 2161
                    Re: Lg 42pj350
                    yeah thanks alot mate for the help all i want now is to open up the usb to play movies but looking around at the moment how to do it
                    • tw2005
                      • Oct 2011
                      • 6458
                      Re: Lg 42pj350
                      Not sure, I'd just be getting a copy of the user guide. Never tried it.
                      • sordids999
                        • May 2013
                        • 2161
                        Re: Lg 42pj350
                        yeah maybe ill leave it wanted to play some movies of my son school plays etc
                        thanks to all that helped also
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          Re: Lg 42pj350
                          did you see this try at your own risk!!!!
                          http://www.lg-hack.info/cgi-bin/sn_f...=2676&tid=3499
                          • sordids999
                            • May 2013
                            • 2161
                            Re: Lg 42pj350
                            yeah but i thought ill leave it thanks though
                            • Bilbo44uk
                              • Jun 2014
                              • 11
                              Re: Lg 42pj350
                              I have been working on one of these LG sets recently, and have found they are a bit of a troublesome set, they seem to have a few stock faults, engineers seem to want to hide whats causing these issues which not only wastes people like you and me who are trying to fix them, but is also highly frustrating.
                              The power Supply on many of these 42-50" sets uses a Thyristor, and Resistor Load system, when you switch the tv off a microchip underneath the psu sends a Discharge signal (16 V) to the Thyristor, this opens a gate slowly and discharges the capacitors on the ysus and xsus boards into the two 22 Ohm 5 Watt resistors, across the gate and drain of the Thyristor your see a small signal capacitor usually either a small electrolytic 100Uf 16V or a small ceramic 104 marked cap, it depends on the design, on the sets ive had in the 100uf cap had a high esr of 2 ohms but the UF reading was fine, on unsoldering it i compared it with a new one and it was a different reading the new one being 0.4 ohms ESR, if you then charge the capacitor on a 9 volt battery and use and analog meter like an AVO8 your see it drops very jerky and then falls like a stone to 0v, test a new capacitor and it should drop smoothly to 0V, the capacitor seems to hold the gate open then close it, this then lets the ysus and xsus panels drain down through the 2 x 22 ohm resistors to ground, if the capacitors shot only an esr meter will tell you, the gate is held open two fast and the surge blows the resistor open on turn off, replacing it will blow it again sooner or later, change the capacitor, the other stuff about current control IC and diodes on the net is not the issue here.
                              When the resistor blows usually the lower one the IC detects a start up fault and clicks twice the relay and the power supply is then shut down, replacing the resistor will not solve the problem for long, I have watched all the info on the guy in the USA changing Diodes and Current control ICs but ive never seen this happen yet on these sets, I think he maybe just having bad luck, the kits are available on ebay, but the current control IC is easy enough to test anyway, i think a lot of this issue is bad quality capacitors on these LG boards.
                              • shouri
                                Dell latitude e5490 auto restart
                                by shouri
                                Hi guys, can someone help me?
                                I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
                                Board model is dm70 la-f401p rev:1.0 2017-09-20.
                                At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
                                After a few days test, is seems ok.
                                Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same....
                                12-10-2024, 09:27 PM
                              • fulepost@outlook.com
                                Samsung "QE" series QE55Q70RATXXC Intermittant restart in "home mode".
                                by fulepost@outlook.com
                                Dear all.
                                I'm a less knowledgable member who would appreciate some guidence.
                                I have a Samsung QE55Q70RATXXC that works perfectly in "shop mode" but in home mode it restarts, Intermittantly.
                                With intermittant I mean the TV can work perfectly for a week and suddenly start to restart. Before the restart it may reach different stages. Sometimes it restarts when the "QLED" start screen shows up and some thimes it restarts after hours, and everything in between.
                                When the restart occurs, the screen blacks out leaving a light area alomng the edges fading...
                                11-09-2025, 07:10 AM
                              • maleksa
                                Yamaha MOX8 boot freeze and distorted sound
                                by maleksa
                                My Yamaha MOX8 synthesizer recently developed two issues.
                                Firstly, after booting up, it operates as normal. However, after about 5 minutes, the sound starts to get distorted (broken up screeching sound) almost like putting it through a guitar distortion pedal. After a while, the distorted sounds will go away for a while and comes back. At times, the synthesizer will also freeze I need to power off and on again.
                                Secondly, when powering off and on again, there will be times where the synthesizer will freeze during the boot sequence (freezes at the MOX8 Opening Screen),...
                                11-07-2024, 03:28 AM
                              • GRANDGG
                                LG 42lw4500 flashing red light , wight light , 2 clicks
                                by GRANDGG
                                Hi i have an issue with LG 42lw4500 wich after pressing the power button flashes red then goes solid white light 2 clicks and nothing , the weird thing is SOMETIMES if i leave the tv plugged in it would come on and fuction normally (i should mention that vertical rectangle going from the bottom to the top of the screen have some red dot artafacts it only appear in somthing like the tv input menu and any input i give like vga , but not in the system menu , i thought i should mention this , i cannot confirme if the tv had this issue when it was up and running in its previous owner . ) when checking...
                                05-09-2025, 12:27 PM
                              • alex26
                                Samsung Qled QE58Q60 restart
                                by alex26
                                Hello. I have a Samsung qled model QE58Q60TAU.
                                The TV restarts continuously and without an image. If I disconnect either half, the TV does not restart, but in both situations I have absolutely nothing on the display, only the backlight is on. I checked the CKv signals and the rest VGH, VSS etc. I measured them against the ground and between them and found between VGH and VSS a resistance of 106 ohms on the B side of the screen (right). I isolated all the signals on the right side and covered them with scotch tape and absolutely nothing has changed, it doesn't restart but I have no picture...
                                12-29-2024, 03:12 AM
