Dell projector 1200MP
  • superg
    • Dec 2013
    • 58
    • Barbados
    Got this projector yesterday. The lamp was replaced but it does not come on. It does the initial self test then attempts to come on. The lamp starts to light dimly then the projector goes off and the power led flashes continuously.
    • 31084
    Re: Dell projector 1200MP
    do the fans spin?
    most projectors shutdown if they dont detect the fans spinning.
    • superg
      • Dec 2013
      • 58
      • Barbados
      The two I can see are.
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • vestaviascott
        Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
        by vestaviascott
        Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
        Here's what happens:
        1) Power on
        2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
        3) Blue status light flashes for appx 4 minutes...
        07-29-2020, 06:08 AM
      • platinumsteel
        Epson VS250 Projector Lamp Not Working.
        by platinumsteel
        Hi guys gooday i have a Epson VS250 Projector that turns on and is also being recognized and detected by the computer when i plug the hdmi cable.The only issue the projector lamp is not working .Are these lamps repairable ? Or i should just forget repairing the lamp and just buy a replacement. Thanks...
        04-09-2023, 04:03 PM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
      • F R 2568
        Dell Latitude 5420 does not start (no post) need help to find the reason why
        by F R 2568
        Hello all,
        this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
        I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
        If the laptop is only connected to the AC adapter (battery removed):
        When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
        The power/battery...
        01-08-2025, 05:45 AM
