Visio E320VA No sound
  • ny_jets_head
    • Apr 2014
    • 70
    • usa
    No sound but I get a light buzzing noise when in the speakers when connected to the HDMI port or any other mode for audio.
    Everything else seems fine.
    Thanks!
  • audiofreak19
    • Apr 2013
    • 556
    • usa
    Re: Visio E320VA No sound
    Do you have a multimeter. If so and I doubt this is the problem but you could check the speakers resistance to make sure it's within spec and not blown. They usually have the magnet marked 4ohm or 8ohm or 16ohm ect.
    • ny_jets_head
      • Apr 2014
      • 70
      • usa
      Your right I also doubt it.
      When I change the setting to turn off the speaker the wine goes away so I suspect they work, also not likely that both would fail at the same time.
        Do you get audio at the RCA Red and White jacks line out?
        • ny_jets_head
          • Apr 2014
          • 70
          • usa
          Unfortunately this set does not have line out RCA jacks only line in
          • ecking767
            • Oct 2009
            • 492
            I have ran across a couple of Vizio E420VA 42" with the same problem, There was a fuse that was blown on the main board, so I replaced the fuse, the audio chip, I check other components surrounding the audio chip, fuse stop blowing, but still no audio. sold the main board as is
            • ny_jets_head
              • Apr 2014
              • 70
              • usa
              What were the components you changed I don't have a print for it so anything info would be helpful.
              • ecking767
                • Oct 2009
                • 492
                post pictures of your main board and power supply
                I was using the datasheet from the audio chip as a reference
                • Alastair E
                  Chief Womble
                  • Mar 2013
                  • 1963
                  • U.K.
                  Not the one with the TA2024 Tripath chip is it?
                  TELEFIX
                  • ny_jets_head
                    • Apr 2014
                    • 70
                    • usa
                    Pic's attached
                    • ecking767
                      • Oct 2009
                      • 492
                      You can start by checking the fuse for the +12v going to the audio section. You will have to remove the heat sink to examine the audio chip if the fuse is blown
                      • ny_jets_head
                        • Apr 2014
                        • 70
                        • usa
                        Sorry for the late reply
                        Thanks I will check those.
                        • ny_jets_head
                          • Apr 2014
                          • 70
                          • usa
                          Fuses are OK
                          I now have a added issue .. I tried to reset the unit and now I can't get past the language screen and none of the button on the side of the set work... might just have to scrap it or get a cheap main board.
                          The cost for main boards on ebay don't make sense for a sub $200.00 TV
                          • knucklfrank
                            • Sep 2014
                            • 4
                            I have the same original prob as Ny Jet Head, i have great pic but no sound but a feedback hum in the speakers, i followed the check Eking 676 suggested and i have continuity across both fuses F701 and F702. is there anything else to check from here? I have the same model also. Viseo says its to old (5yrs) and buy a new one, the picture is great, got to be someway to save it.
                            • ChaosLegionnaire
                              by ChaosLegionnaire
                              09-13-2022, 09:02 AM
                            • valente222
                              LAPTOP HP 15-DY2059LA / i3-12gen has stability problems in vccpu coils, BUZZING SOUND. ¿Coil whine?
                              by valente222
                              Hello friends, I just received this equipment, it has a strange hum on the board. The computer works fine, outputs an image and starts Windows. But the problem is when charging the battery, a constant loop to charge. In short, it never charges the battery. When the charger is connected, the stability of the CPU is stressed and it seems that the coils make that electrical sound louder. This board is modern and I don't have a schematic. I have checked with a microscope and the pcb is completely new. Has anyone had this happen to them before? defect in driver ic?...
                              11-18-2024, 03:21 PM
                            • Christos Tsiligiannis
                              Marian Trace Alpha sound card repair help
                              by Christos Tsiligiannis
                              Hello to the forum.
                              My name is Christos, I am new to the forum here and i am posting from Greece.
                              So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                              To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                              So i tried asking for a schematic from the company and they would not give me one. Instead they...
                              11-18-2024, 05:26 AM
                              HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
                              This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                              09-12-2024, 02:30 PM
                              HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
