Bush LY1911WCW Blowing Mains Fuse
  • anotherdude
    • Feb 2013
    • 488
    Picked this up free a few weeks ago and as it kept blowing mains fuses I didn't go any further
    but have some time now so thought i'd take another look
    nothing obvious from what i can tell maybe 1 part on the back on the secondary side (f1 near the main board power connector, looks whitr but with tinges of brown round the sides) but assuming this is irrelevant as if it's blowing main fuses it has to be a problem primary side?
    • 31041
    Re: Bush LY1911WCW Blowing Mains Fuse
    check the bridge rectifier & the fet on the heatsink for shorts between any of the pins.
    • anotherdude
      • Feb 2013
      • 488
      thanks just been googline ad seen about a rectifier
      am i right to assume if the rectifier or fet has blown it'll of took out the diodes and resistors surrounding them?
        • 31041
        no.
        btw, you said it blew the fuse?
        what fuse.
        the brown box near the power connector is a fuse!
        • anotherdude
          • Feb 2013
          • 488
          no.
          what fuse.
          ye seen that labelled F2 on the board
          seems to check out fine, fuse blowing is at the wall going into the socket, 3 pin plug going into a 3 pin socket (uk plug)
            • 31041
            meter across the power connector on the board to see if it's really shorted.
            it's unlikely, but it could be a bad power switch or damaged mains cable - i'v seen that once.
            • anotherdude
              • Feb 2013
              • 488
              seems you could be correct
              removed the mains cable and used another and it's now no longer blowing the mains fuse but i'm seeing little to no voltage across the power supply
              • Alastair E
                Chief Womble
                • Mar 2013
                • 1963
                • U.K.
                As in--No 240V getting To the PSU board?
                Set Mains power-switch, or fuse on any mains-filter boards? Fuse in the replacement power-lead? Is there power to the wall-socket, after you blew out the fuse earlier, coulda taken the trip for that ring-main out in the house-breaker....
                The latter, I'm often falling foul of with the supply-fuse to my isolating-transformer--I go round head scratching for a while--before penny drops....
                TELEFIX
                  • 31041
                  that's why you can never have too many led's & neon lights
                  • anotherdude
                    • Feb 2013
                    • 488
                    that's it well kind of, theres no voltage at where the voltage comes in, but the fuse is good and so is the socket, tested the toaster with both
                    not sure whats happened tbh, even disconnected from the power board and measuring the output from the wall to the output I get nothing
                      • 31041
                      so socket good.
                      plug & fuse presumed tested.
                      check the cable for continuity on both conductors.
                      is it a molded plug?
                      and is there a chassis switch on the tv? all the tv's i'v got with built-in cable have a rocker switch on the back.
                      • Alastair E
                        Chief Womble
                        • Mar 2013
                        • 1963
                        • U.K.
                        Ive had a couple of IEC type mains-leads go faulty, on one--the moulded in fuse-holder in the plug was loose, not making connection....
                        TELEFIX
                        • anotherdude
                          • Feb 2013
                          • 488
                          so socket good.
                          it is a moulded plug, there is a rocker switch but I bypassed that as I think that was what was causing the fuses to blow
                          fuse tests good as does the cable
                          • Alastair E
                            Chief Womble
                            • Mar 2013
                            • 1963
                            • U.K.
                            Have you Tried the cable--say in the kettle....?
                            Check continuity with DMM from the set power-socket to the PSU plug and onto the PSU board...
                            TELEFIX
                              • 31041
                              in the kettle?
                              tv's use 3amp cable!
                              just puting a 60w lamp on the end will be enough.
                              • Alastair E
                                Chief Womble
                                • Mar 2013
                                • 1963
                                • U.K.
                                In The UK......
                                We use those leads with 13A fuse--to power elect kettles!
                                First thing that came to mind to test the lead with. TV's in the UK seem mostly to have 10 and 13A fuses fitted in the IEC lead plugs....
                                TELEFIX
                                  • 31041
                                  i'v not seen many tv's wih IEC, mostly captive cable.
                                  probably because it's cheaper.
                                  that said, IEC should not fit a kettle.
                                  kettles use HOT-IEC with a notch in the connector and a blocking piece in the kettle.
                                  so you cant use a cable that isnt rated for high temperatures.
                                  • anotherdude
                                    • Feb 2013
                                    • 488
                                    so pinched a cable from a 22 inch lcd whats smashed, same connector tested the smashed one first to double check the fuse and i get a standby light (can't lay my hands on the remote) so that cable does work,
                                    so plugged it into this bush psu, no standby light and voltage jumping at the ac in pin
                                    tested the previous cables on the smashed lcd I had tried on this bush and all work fine, so still a short somewhere maybe?
                                    no idea what was going on earlier with the previous cables
                                    now seeing high resistance at the f2 fuse and no continuity when off, guess my MM is playing silly beggers
                                    also it's not that typle of lead, it's just the straight 2 pin connector you'd see coming from the mains connector to the power board (if that makes sense brown and blue wire only)
                                      • 31041
                                      o.k.
                                      put a new battery in your meter.
                                      then check the bridge rectifier & fet for shorted pins.
                                      • anotherdude
                                        • Feb 2013
                                        • 488
                                        realised what i'd done earlier now, as I was using a different cable to test i must of inserted it the wrong way (blue to brown/brown to blue)
                                        how stupid of me
                                        DMM is fine as far as I can tell measured a few batteries and got the right readings, ordered another f2 fuse and the rectifier and fet anyway just in case
                                        high resistance at the f2 would mean it's blown? and the reason i'm seeing no other voltages anywhere?
                                          Surface Mount Fuses Fundamentals Datasheet
                                          TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                          TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                          10-07-2024, 06:07 AM
                                        • stav242
                                          Samsung BN44-006056A Blowing Mains plug fuse.
                                          by stav242
                                          ive picked up a Samsung UE32F5500AK TV with a BN44-006056A power pcb.
                                          It was reported as `blowing the fuse` - the 3A one in the plug.
                                          on quick inspection of the power pcb, a ceramic capacitor CM802 has blown apart.. photo attached.
                                          Ive found a PDF of the circuit schematic and can identify the neighbouring components (RM801, RM802) but cannot find CM802 on the schematic.
                                          Can anyone identify what CM802 is ?
                                          thanks.
                                          S....
                                          12-30-2021, 10:45 AM
                                          TF-FUSE Thin Film Surface Mount Fuses (Very Fast Acting), 0603 Size Datasheet
                                          FF Series (Very Fast Acting), 0603 Size
                                          Features
                                          ● Very fast acting at 200% overload current levels
                                          ● Low DCR
                                          ● High inrush current withstanding capability
                                          ● Fiberglass enforced epoxy fuse body
                                          ● Copper termination with nickel and tin plating
                                          ● Halogen free, RoHS compliance and lead-free
                                          Applications
                                          ● Notebook computers and tablets
                                          ● Digital cameras
                                          ● Memory cards
                                          ● Toys
                                          ● Bluetooth earphones
                                          ● Portable electronic devices​...
                                          10-07-2024, 05:50 AM
                                          1970 Metal Lathe Control Circuit blowing fuses on the 120 volt section failing meager test below 60 mega ohms
                                          by sam_sam_sam
                                          I was working on this machine yesterday and I now going to use an incandescent lights instead of a fuses to figure out what the issue is with it blowing control voltage rail but this not the only issue the coolant pump failed the meager test as well as the main motor as well this motor has 12 motor wire leads instead of the normal 9 wires
                                          This metal lathe has a weird motor setup it has a soft start motor with a “Y” and a delta type of motor winding setup and it is not done in the motor pucker head enclosure it is with four different contactors wired in a configuration I have not...
                                          12-29-2024, 07:18 AM
                                        • Tips
                                          Samsung PD27AOQ (BN44-00506B) constantly blowing internal fuse.
                                          by Tips
                                          Looking for some assistance please.
                                          Trying to repair a PD27AOQ samsung power board.
                                          Initially had the typical problem of cm806 capacitor blown, additionally thermistor NT801s blown.
                                          Replaced the ceramic capacitor, str60252s, bridge rectifier, thermistor and fuse.
                                          Testing it the fuse blows immediately power is turned on.
                                          diodes dm852 and dm853 test as shorted when in the board but fine when removed.
                                          any assistance, guidance would be appreciated.
                                          04-11-2024, 11:24 AM
