Samsung UN46D7000 Turns on and Off
  • w98seeng
    • Apr 2014
    • 19
    Re: Samsung UN46D7000 Turns on and Off
    Originally posted by tibimakai
    The Power ON/OFF is constant 3V or is oscillating?
    Constant 3.73V
    Here are more accurate voltages (if it helps). Everything is constant, no fluctuations.
    1. OD_LEVEL - 5.3V
    3. OD_ON/OFF - 5.09V
    5. GND
    7. B13V - 13.86V - With the screen connectors connected, the voltage is 13.74V
    9. B13V - 13.86V - With the screen connectors connected, the voltage is 13.74V
    11. V amp - 13.86V - With the screen connectors connected, the voltage is 13.74V
    13. V amp - 13.86V - With the screen connectors connected, the voltage is 13.74V
    15. GND
    17. B5V - 5.39V
    19. B5V - 5.39V
    2. P-DIM4 -
    4. P-DIM3 -
    6. P-DIM2 -
    8. P-DIM1 -
    10. B13V - 13.87V
    12. BLU ON/OFF - 4.74V
    14. GND
    16. GND
    18. A5V - 5.39V
    20. POWER ON/OFF - 3.37V
    Ian
    • w98seeng
      • Apr 2014
      • 19
      More info. I got the TV to work, but only for a minute or so.
      I took off the cable from the power board to the main board and took wires 1-10 out of the connector. I put back in 3 wires twice (nothing working, but no clicking either) then I started 1 at a time.
      When I got to wire 7, the TV started to act normal (no clicking, normal on/off button) with sound, but no picture. I plugged in wire 9 and the picture came on. The only wire not connected was wire 10 (B13V). The TV worked for about a minute and then started the on off cycle again.
      Any ideas?
      Ian
      • w98seeng
        • Apr 2014
        • 19
        Well, I bought a power supply (BN44-00427B) that I was assured works perfectly (taken out of a TV with a cracked screen) and the TV does the same thing.
        This time though, with the cable disconnected from the main board, the backlight does light up and the TV still clicks on and off. With the old power supply, and
        with the cable disconnected from the main board the TV did not click on and off and the backlight never came on.
        I'm going to reflow the main board, nothing to lose.
        Ian
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          How are you going to reflow mainboard?
          --Just curious......
          TELEFIX
          • tibimakai
            • Jan 2012
            • 3680
            It seems that your situation is different that what I have experienced. The power on/off voltage it was turning on and off on mine.
            • w98seeng
              • Apr 2014
              • 19
              I plug in the power supply with all connections and it clicks on and off. I plug it into just the power and nothing else and it clicks. I called the guy who said he has been working in
              electronics for 28 years and told him this and he told me the main board damaged the power supply he sold me.
              I think I'll just take the TV into Samsung and have them diagnose this problem, I'm getting nowhere with the internet and just wasted money on a used power supply.
              • SONICBOOM808
                • Mar 2015
                So what was the final result? I ask because my TV is doing the exact same thing. Thanks in advance.
                • ilzi92
                  • Sep 2014
                  • 14
                  • Österreich
                  #28
                  I have a Samsung TV (UE40F6500), but it have no picture, audio works fine...
                  5V at Blu ON/OFF
                  but no voltage @ OD_ON/OFF --- for which is this responsable ??
                  best regards
                  • sordids999
                    • May 2013
                    • 2152
                    • uk
                    #29
                    @ilzi92 i would consider making a separate thread on your issue plus Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
                    • sylves
                      • Apr 2016
                      • 10
                      • usa
                      #30
                      Backlight failer!!!!!!!!
                      • zomi
                        • Nov 2011
                        • 505
                        #31
                        Bad mainboard
                        Corrupted nand .. common error on the xxdxxxx series.
                        • sylves
                          • Apr 2016
                          • 10
                          • usa
                          #32
                          • sylves
                            • Apr 2016
                            • 10
                            • usa
                            #33
                            • Gdog215
                              • Mar 2018
                              • 29
                              • Usa
                              #34
                              I have un46d7000 with the constant reboot problem. Found a replacement board for a good price, these boards are pricy. Installed the new board, it's still rebooting. Is it the nand chip or led strips?
                              You live and you learn right?
                              • neilc6
                                • Nov 2015
                                • 1550
                                If you looked at the service bulletin posted, an open LED string will cause rebooting.
                                • m1ch43lzm
                                  by m1ch43lzm
                                  05-12-2025, 08:37 PM
                                • mrtek
                                  Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
                                  by mrtek
                                  Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
                                  11-26-2024, 09:58 AM
                                • ohren
                                  Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                                  by ohren
                                  I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                                  I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                                  The models launched in 2018 and 2019 respectively....
                                  09-08-2023, 05:24 PM
                                • C152Heavy
                                  Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                                  by C152Heavy
                                  Summary for TL-DR readers:
                                  • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                                  • Have obtained Samsung schematic & service documents - Can upload if helpful.
                                  • Have read ALL applicable threads
                                  • C1818 and CP820 replaced as low hanging fruit
                                  • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                                  • VCC pin (18) of PFC...
                                  01-11-2023, 02:53 PM
                                • Chrissygizmo
                                  by Chrissygizmo
                                  02-10-2025, 12:33 AM
