SANYO CES32WSD7-B Blurry Screen - Help Please
  • SmartestSmarty
    • Jan 2014
    • 50
    • United Kingdom
    Hello all,
    I have a Sanyo CES32WSD7-B
    The tv set turns on fine and you can hear and see an image. Sometimes the image is perfect, and other times, it is very blurry, or the image moves in slow motion, with a residual kind of effect. For example if someone walked across the room, you can still see them where they were initially standing for a second or two before it catches up.
    Like I said sometimes the picture is perfectly fine.
    I highly doubt its the ariel, or the screen.
    Any suggestions what I should check?
    Thanks in advance.
  • SmartestSmarty
    • Jan 2014
    • 50
    • United Kingdom
    Re: SANYO CES32WSD7-B Blurry Screen - Help Please
    Oh and sometimes the screen is completely blank.
    Please help.
    • martino
      Not so "senior"
      • Aug 2013
      • 997
      • canada
      Is it intermittent,like changes from good,then bad etc...or it's however it decides to fire up,thats how it stays?
      Proud owner of dozens of broken TV's and many,many,many boards.
      Our website and passion:http://hollenhundshepherds.com/
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        Probably the tabs on the LCD panel itself. Sometimes it can be cured by attaching foam-rubber or summit to put light pressure where these attach the glass at one end and the PCB the other.
        This is not a proper repair--only panel replacement is a proper cure.
        TELEFIX
        • SmartestSmarty
          • Jan 2014
          • 50
          • United Kingdom
          Yes I would say it is intermittent.
          Sometimes you turn it on and it's completely blank and stays that way.
          Sometimes you turn it on and it has a picture but then goes blurry, and/or blank.
          Can you elaborate a bit more on the attaching rubber method? a bit confused here.
          Any other suggestions as well would be appreciated.
          Thanks a lot for your help so far.
            This is a Vestel made TV so I am guessing it has a Chimei or AUO panel, which are well known for tab bond faults.
            • SmartestSmarty
              • Jan 2014
              • 50
              • United Kingdom
              Thanks for the reply,
              So what would be the best solution?
                You can try shimming the tabs but it may not be economical to repair; look up youtube - "Tab bond repair Sony".
                • dicky96
                  HP Elitebook Screen blank - backlights but no image
                  by dicky96
                  Hi guys
                  I'm trying to fix this laptop screen
                  Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
                  OK so I have the original screen which works but has lines across the bottom quarter of the screen
                  I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
                  04-28-2021, 07:30 AM
                • Ryan.man
                  by Ryan.man
                  02-04-2025, 12:23 PM
                • reformatt
                  by reformatt
                  07-31-2025, 08:37 PM
                • speedtime07
                  i life zed air cx5 no image on screen
                  by speedtime07
                  hi everyone ,
                  There is an image on the external computer screen ,
                  flexi cable test ok - screen test ok -
                  What alternative should I look for?
                  thank you for your support​
                  04-10-2025, 06:24 AM
                • smic717394
                  by smic717394
                  07-25-2024, 10:16 AM
