Hitachi 57S715
  • pwhite
    • Apr 2014
    • 5
    Hitachi 57S715
    I hear a relay click and DP40 and DP50 leds light then fade. I assume the tv is going into a shutdown. I monitored the secondary voltages and they all come up normally for a second before shutdown.
  • R_J
    • 9549
    Re: Hitachi 57S715
    It was quite common for the convergence ic's to go bad, shorted. Try unpluging PPDC plug (has 3 large wires) from the convergence amp board, should be the board on the right with 2 large heatsinks on it. If the tv comes on with no convergence correction, teh stk*** ic's are bad, (only one is most likley bad but replace both)
    • pwhite
      • Apr 2014
      • 5
      Re: Hitachi 57S715
      I appreciate your response. I pulled the connector on the convergence board but still in shut down. Vertical IC next possibly?
      • R_J
        • 9549
        Re: Hitachi 57S715
        check dp32 bridge rectifier and cap cp03 for bad connections.
        also does the power led on the front of the tv stay on?
        also check the pico fuses, ep01 & ep02, but I think they will be ok.
        I have'nt worked on one of these sets in a long time.
        • pwhite
          • Apr 2014
          • 5
          Re: Hitachi 57S715
          It has been a long time for me as well. Many a late night trying to figure shutdowns over the years.
          Front panel led does not light up at all. I checked the items above for poor solder connections and the two fuses are good.
          • R_J
            • 9549
            Re: Hitachi 57S715
            I extracted the Power and Deflection schematic from the (32meg) manual it might help.
            • cruiser_
              A1466 820-00165 intermittent shutdown
              by cruiser_
              hi there,
              Got this macbook after liquid damage. Nothing major, cleaned and reflowed what was suspect. Now, the laptop turns on and boots up but shuts off intermittently - sometimes after a few minutes, sometimes after a few hours.
              Can be immediately started from keyboard right after. Plug stays orange during this time. No battery.
              Gives shutdown cause -128.
              Seem to work fine in SMC bypass.
              Same shutdown happens with disconnected TP/KB/KBLED/CAM.
              Observations:
              - SMC_RESET_L - when pulled down - plug goes orange/green and...
              10-11-2022, 12:06 PM
            • massimomax
              Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
              by massimomax
              Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
              spero che qualcuno può averlo per riprogrammare eprom. grazie
              Post in English !!!
              I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
              02-28-2025, 07:27 AM
            • RATIM SIDDIQUE
              hp fpw50-la-h323p rev 1.0 automatic shutdown after 30 sec, need help
              by RATIM SIDDIQUE
              automatic shutdown after 30 sec of display coming
              do not shutdown without ramstick
              someone give me idea plz
              08-20-2024, 03:50 AM
            • howardc64
              P502UI-B1E shutdown automatically after 75s followed by power light blinking 15x
              by howardc64
              History
              - Got TV free. Prior owner claims Vizio logo shows up then nothing. He found U202 EEPROM replacement info (I know NickTV says its never EEPROM haha). Lifted 5 pads removing U202 without proper tools and thought thats end of main board. Gave the TV to me.
              - I repaired U202 pads and connections. Soldered on prior owner purchased aftermarket EEPROM (original EEPROM was tossed). TV boots to VIZIO logo, then goes blank, shutsdown after a min or so and power on light blinks a number of times.
              - Fixed 2 circa 2015 Vizios before with classical main board...
              11-28-2020, 04:25 PM
            • dragometin
              Hitachi 40HYC42
              by dragometin
              TV Model: Hitachi 40HYC42
              Power Supply: 17IPS71
              MainBoard: 17MB95M
              Panel: VES400UNDS-2D-NO3
              When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
              I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
              Is there any variants on 17IPS71 power supply's?
              UART output pins 10 and 12 on scart connector:
              Code:
              12:24:04.595
              08-08-2024, 05:53 AM
