Hitachi 57S715
  • pwhite
    • Apr 2014
    • 5
    Hitachi 57S715
    I hear a relay click and DP40 and DP50 leds light then fade. I assume the tv is going into a shutdown. I monitored the secondary voltages and they all come up normally for a second before shutdown.
  • R_J
    • Jun 2012
    • 9588
    Re: Hitachi 57S715
    It was quite common for the convergence ic's to go bad, shorted. Try unpluging PPDC plug (has 3 large wires) from the convergence amp board, should be the board on the right with 2 large heatsinks on it. If the tv comes on with no convergence correction, teh stk*** ic's are bad, (only one is most likley bad but replace both)
    • pwhite
      • Apr 2014
      • 5
      Re: Hitachi 57S715
      I appreciate your response. I pulled the connector on the convergence board but still in shut down. Vertical IC next possibly?
      • R_J
        • Jun 2012
        • 9588
        Re: Hitachi 57S715
        check dp32 bridge rectifier and cap cp03 for bad connections.
        also does the power led on the front of the tv stay on?
        also check the pico fuses, ep01 & ep02, but I think they will be ok.
        I have'nt worked on one of these sets in a long time.
        • pwhite
          • Apr 2014
          • 5
          Re: Hitachi 57S715
          It has been a long time for me as well. Many a late night trying to figure shutdowns over the years.
          Front panel led does not light up at all. I checked the items above for poor solder connections and the two fuses are good.
          • R_J
            • Jun 2012
            • 9588
            Re: Hitachi 57S715
            I extracted the Power and Deflection schematic from the (32meg) manual it might help.
            • kacangpolo
              Asus X415EA Auto start when shutdown ( Laptop cannot shutdown with baterai only )
              by kacangpolo
              I have problem with my laptop, with code board X415EA 2.0,
              laptop cannot shutdown with baterai only, if i plug the adaptor, laptop can shutdown, but when the adaptor was unplug, laptop wake up
              I did :
              1. Flash Bios
              2. RTC_RST 3.3V
              3. LID_SW 3.3V
              4. WLAN_WAKE# 3.3V
              08-26-2025, 04:42 AM
            • Jaime Morillo
              Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
              by Jaime Morillo
              Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
              The TV was stuck on the logo and I couldn't access the update menu.
              I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
              The image result was good, but the image is inverted.
              The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
              Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
              08-18-2025, 11:38 AM
            • cruiser_
              A1466 820-00165 intermittent shutdown
              by cruiser_
              hi there,
              Got this macbook after liquid damage. Nothing major, cleaned and reflowed what was suspect. Now, the laptop turns on and boots up but shuts off intermittently - sometimes after a few minutes, sometimes after a few hours.
              Can be immediately started from keyboard right after. Plug stays orange during this time. No battery.
              Gives shutdown cause -128.
              Seem to work fine in SMC bypass.
              Same shutdown happens with disconnected TP/KB/KBLED/CAM.
              Observations:
              - SMC_RESET_L - when pulled down - plug goes orange/green and...
              10-11-2022, 12:06 PM
            • wolf1976
              hitachi 50hk5600 problem with display
              by wolf1976
              hi
              i have the above tv and the display starts distorts the display at only in applications like you tube
              after and on the didital channels
              now without connect the antenna only the image of itsselfs tv i have the image i have in attach
              i have read in another forum someone else with similar problem with mine changes tcon card and motherboard and the problem remains
              can you tell me someone what is the reason that can causes that problem ? is the same the sisplay ?...
              09-13-2025, 02:26 PM
            • massimomax
              Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
              by massimomax
              Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
              spero che qualcuno può averlo per riprogrammare eprom. grazie
              Post in English !!!
              I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
              02-28-2025, 07:27 AM
