No Standby Light on Samsung SAMSUNG UE65NU7022
  • SJX1290
    • Sep 2024
    • 28
    • Slovenia
    👍🏻..thanks again
    • lotas
      • Jan 2016
      • 4708
      • Russia
      This is not the same, this textolite number, it can be used under a different model number, with a different matrix, with a different region...
      This is the number you need to search for. (BN94-xxxxx)
      • SJX1290
        • Sep 2024
        • 28
        • Slovenia
        ok
        • lotas
          • Jan 2016
          • 4708
          • Russia
          Yes.
          • SJX1290
            • Sep 2024
            • 28
            • Slovenia
            can I get MB with same textolite number ( smaller size tv 55") and change dump?
            • lotas
              • Jan 2016
              • 4708
              • Russia
              #26
              It may not help, besides dump, you also need to reinstall the position resistors.
                • 12214
                • U.S.
                #27
                Any update?
                • SJX1290
                  • Sep 2024
                  • 28
                  • Slovenia
                  #28
                  Tryed some more to find problem, no success.... I just got MB from same series but 55". I will try with transition to 65",...pls advice with position resistors
                  • SJX1290
                    • Sep 2024
                    • 28
                    • Slovenia
                    #29
                    I have now 55" MB from same series... how to deal with position resistors, where are located and what to do with them
                    • lotas
                      • Jan 2016
                      • 4708
                      • Russia
                      #30
                      You need to compare for yourself, mostly they are located in the t-con area (mostly they are rearranged for different panel manufacturers AUO, BOE, Samsung...).
                      • SJX1290
                        • Sep 2024
                        • 28
                        • Slovenia
                        #31
                        Problem solved, new motherboard from 55", t-con flash 25Q8VD reprogramed with content of same 65". So far TV working with no issues withouth any change of position resistors.
                        • lotas
                          • Jan 2016
                          • 4708
                          • Russia
                          #32
                          You're lucky, they don't always change, if the 25Q80 (t-con) firmware didn't help completely, then you need to rearrange the resistors, just like on the original motherboard.
                          • SJX1290
                            • Sep 2024
                            • 28
                            • Slovenia
                            #33
                            👍Thank you for your help, ...till next challenge🙂
                            • Michael Long
                              No Standby Light on Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                              by Michael Long
                              I had a Dead Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                              Dead / No Power / No Standby Light results after power company had three
                              consecutive power outages on/off/on/off/on/off after which TV was rendered unresponsive.
                              After exploring the issue found Mainboard was the fault. Then with research on this site determined IC1604 was the suspect. The IC1604 is a surface mounted device (SMD) EEPROM, Winbond Model 25Q40CLSIP. A read on this EEPROM came back with all FF FF FF FF FF in all registers blank and empty of data. I had a spare mainboard with intact IC1604 and utilized...
                              09-13-2022, 06:55 AM
                            • ChristianBr01
                              LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                              by ChristianBr01
                              I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                              The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                              What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                              04-23-2025, 01:48 AM
                            • Kaar3l
                              Samsung QLED QE65Q7FNAT only standby light
                              by Kaar3l
                              TV: Samsung QLED QE65Q7FNAT
                              PSU: BN4400940A
                              MB: BN94-12832K
                              I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                              09-24-2024, 01:35 PM
                            • Nicktronic
                              Samsung UN70NU6070F Standby Light flashes twice
                              by Nicktronic
                              Hey Everyone,
                              So I've got this Samsung and the reported issue is that when powered on the backlight comes on, but no picture, no sound, it will flicker, the standby light will flash red twice and repeat the whole process...each loop lasts about 15 seconds.
                              I've googled the issue and understand it is likely a panel/driver board issue, but was hoping the "tape method" could be successful. Before I did that though, I disconnected the left LVDS cable and powered the TV on. This time I got sound, no picture and the two blink standby light stopped. Did the same...
                              03-27-2023, 07:01 PM
                            • marcinq
                              Samsung UE60KS7000 No Standby Light
                              by marcinq
                              I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
                              I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....
                              05-26-2025, 11:36 AM
