No Standby Light on Samsung SAMSUNG UE65NU7022
  • SJX1290
    • Sep 2024
    • 28
    • Slovenia
    I have Samsung UN65MU6300FXZA with Mainboard BN41-02662A, dead , No Standby Light. I suspect result of main power jumping. Checked all voltages on main board ok,..
    My main suspect is bad flash memory, ...
    Any suggestions or can someone please​ check dump file, in the attachment
    Thank you
  • lotas
    • Jan 2016
    • 4589
    • Russia
    Any suggestions or can someone please check dump file, in the attachment
    Thank you
    So which TV do you have: SAMSUNG UE65NU7022 or Samsung UN65MU6300FXZA?
    Try this dump.
    • SJX1290
      • Sep 2024
      • 28
      • Slovenia
      ..oh sorry, UE65NU7022, one in mind, one stays in comp
      • lotas
        • Jan 2016
        • 4589
        • Russia
        So did my dump help you?
        • SJX1290
          • Sep 2024
          • 28
          • Slovenia
          No, still nothing. Maybe I am doing something wrong or...when I delete flash is till some dato on (picture Reset), and after reprograming shows me Verifivcation error (pic 2 Dump)
          • lotas
            • Jan 2016
            • 4589
            • Russia
            Start by removing the protection (status register), erasing the chip, recording and checking. It is better to use NeoProgrammer V2.2.0.10.
            • SJX1290
              • Sep 2024
              • 28
              • Slovenia
              Iam programing with chip on board, is it better do desolder/remove it?
              • lotas
                • Jan 2016
                • 4589
                • Russia
                Yes, it is better to unsolder through an adapter....
                • SJX1290
                  • Sep 2024
                  • 28
                  • Slovenia
                  This time started with led light, but shortly vent off, after short time started blinking, 5 times ... then again one long red light and 5 shorter....and shows that remote signal is recepting
                  • lotas
                    • Jan 2016
                    • 4589
                    • Russia
                    Does the backlight turn on when the motherboard is turned off?
                    • SJX1290
                      • Sep 2024
                      • 28
                      • Slovenia
                      When I disconnect MB backlight is on...have two same TVs, one is ok, so checked most of other scenarios. We are nov one step further...what about other flah chip 25q80..was wondering if maybe this one is also corrupted
                      • EazyBone
                        • Jun 2023
                        • 1321
                        • United states
                        Did you swap boards from the two identical tvs you have? You have the easiest diagnosis tool there is. Or do you know it's main board and want to fix that way or something
                        • SJX1290
                          • Sep 2024
                          • 28
                          • Slovenia
                          I swaped MB boards, checked power on the one, but is somehow demaged..hopefully are just flash memories, if not, will be change of MB. Diagnosis done..
                          • lotas
                            • Jan 2016
                            • 4589
                            • Russia
                            Yes, try reading from a working TV 25q80 and writing it to this motherboard, provided that their panel numbers are the same (and save your original dump!).
                            • SJX1290
                              • Sep 2024
                              • 28
                              • Slovenia
                              nope, 25Q80 rewriten, same situation..
                              • lotas
                                • Jan 2016
                                • 4589
                                • Russia
                                Try setting and writing status register (0x28,0x00) after writing my dump.
                                • SJX1290
                                  • Sep 2024
                                  • 28
                                  • Slovenia
                                  unfortunatelly same result, start with led light, but shortly vent off, after short time started blinking, 5 times and back again, one long red...
                                  • lotas
                                    • Jan 2016
                                    • 4589
                                    • Russia
                                    Well, apart from the firmware, there is also a problem with the motherboard...
                                    • SJX1290
                                      • Sep 2024
                                      • 28
                                      • Slovenia
                                      Ok, too bad,.. I will look now for new MB. Thank you for all your support, Appreciated
                                      • lotas
                                        • Jan 2016
                                        • 4589
                                        • Russia
                                        Then look for the number on the paper tag, it usually starts like this BN94-xxxxxx.
                                        • Michael Long
                                          No Standby Light on Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                                          by Michael Long
                                          I had a Dead Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                                          Dead / No Power / No Standby Light results after power company had three
                                          consecutive power outages on/off/on/off/on/off after which TV was rendered unresponsive.
                                          After exploring the issue found Mainboard was the fault. Then with research on this site determined IC1604 was the suspect. The IC1604 is a surface mounted device (SMD) EEPROM, Winbond Model 25Q40CLSIP. A read on this EEPROM came back with all FF FF FF FF FF in all registers blank and empty of data. I had a spare mainboard with intact IC1604 and utilized...
                                          09-13-2022, 06:55 AM
                                        • ChristianBr01
                                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                          by ChristianBr01
                                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                          04-23-2025, 01:48 AM
                                        • Kaar3l
                                          Samsung QLED QE65Q7FNAT only standby light
                                          by Kaar3l
                                          TV: Samsung QLED QE65Q7FNAT
                                          PSU: BN4400940A
                                          MB: BN94-12832K
                                          I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                          09-24-2024, 01:35 PM
                                        • Nicktronic
                                          Samsung UN70NU6070F Standby Light flashes twice
                                          by Nicktronic
                                          Hey Everyone,
                                          So I've got this Samsung and the reported issue is that when powered on the backlight comes on, but no picture, no sound, it will flicker, the standby light will flash red twice and repeat the whole process...each loop lasts about 15 seconds.
                                          I've googled the issue and understand it is likely a panel/driver board issue, but was hoping the "tape method" could be successful. Before I did that though, I disconnected the left LVDS cable and powered the TV on. This time I got sound, no picture and the two blink standby light stopped. Did the same...
                                          03-27-2023, 07:01 PM
                                        • marcinq
                                          Samsung UE60KS7000 No Standby Light
                                          by marcinq
                                          I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
                                          I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....
                                          05-26-2025, 11:36 AM
