Techinka 46" LCD no diplay
  • jwilliams1967
    • Apr 2014
    • 54
    Hi .I have inherited this TV from a friend and would am using it as a learning curve so any help would be greatly appreciated.
    The problem.
    when I plug it in I get a blue light at the front and when I switch it on the blue light turns to orange and I have no display at all. The buttons on the side beep when pressed but nothing seems to be happening.
    What I have done.
    With my very limited knowledge I have checked and replaced the caps on the main power supply and the 4 470 Uf caps on the inverter board. some of the caps on the power supply where faulty although not bulging.
    Have checked diodes and transistors as well and am reasonably confident they are ok , but please don't assume I know what im doing ( have used your great guides as reference)
    What I know.
    Im getting 24volts both sides of the fuses on the inverter board and 24volts across the 4 caps.
    I have a buzzing from a transformer on the main power board but have been led to believe this may be normal.
    As I stated im new to all this and am keen to learn but need guidance from some of you more experience people out there .
    Also can somebody take a quick look at the 2 cables that connect the main power supply to the inverter and tell me if the a connected the right plugs .( foolishly assumed the plugs would be different )
    have supplied pictures.
    many thanks .
  • jwilliams1967
    • Apr 2014
    • 54
    Re: Techinka 46" LCD no diplay
    Hi I have found schematic for the power board . maybe this may help.
    many thanks
    • rauno45
      • 48
      • Estonia
      Are these 2 capacitors on the top left capxons? If yes then try replacing them and every other crapxon because they might not be shorted and they might eaven have accurate capacitance value, but it could still have high esr without it showing from anywhere. Thats why a esr meter would become handy. In my case replacing crapxons helped.
      • jwilliams1967
        • Apr 2014
        • 54
        will try that my friend . thanks
        • jwilliams1967
          • Apr 2014
          • 54
          I have now replaced the 2 large caps with Panasonic caps. still has the same problem. just going to check voltages on pl806 28 pin plug and will post results. can anybody point me into the right direct please.?
            Great Sage é½Šå¤©å¤§č–
            • 31029
            buzzing is not normal,
            modern psu's run way above sonic range - 70Khz or more.
              I've had completely functional PSUs buzz, it depends on how they operate and how the control loop is designed. Harmonics and modulation especially.
              • jwilliams1967
                • Apr 2014
                • 54
                here are the readings Ive obtained from pl806 . please see schematic attached .
                (2) 0 (1) NC
                (4) 0.8 (3) 0
                (6) 0 (5) 0
                (8) 0 (7) 0
                (10) 0 (9) 0
                (12) 11.7 (11) 11.7
                (14) 4.2 (13) 0
                (16) 4.2 (15) 4.2
                (18) 3.4 (17) 5.2
                (20) 3.4 (19) 5.2
                (22) 3.3 (21) 5.2
                (24) 0 (23) 0
                (26) 24.3 (25) 24.4
                (28) 0 (27) NC
                please see attached schematic on early post just up the page
                • vinceroger69
                  • Mar 2012
                  • 6714
                  im not sure either about the two connectors from the inverter to the psu maybe there are on the wrong connectors? maybe tom or budm will comfirm for you how im looking at the scheme the connector with the more wires may go to the front connector block not the way u have it but im not experienced enough to read scheme as still learning.
                  • jwilliams1967
                    • Apr 2014
                    • 54
                    same here buddy
                    • jwilliams1967
                      • Apr 2014
                      • 54
                      just thought I would add that I think that the problem I may have is I have no 3.3volt standby
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        yes just noticed that theres some other voltages missing too did you take these with the set in standby do the voltages alter when the sets switched on?
                        • jwilliams1967
                          • Apr 2014
                          • 54
                          the set was in standby because it wont come out of standby
                          • jwilliams1967
                            • Apr 2014
                            • 54
                            just to clarify . when I plug the set in I get a blue light on the front . when I switch it on I get a orange light on the front which stays solid . no display or backlight . the buttons on the side beep when pressed but nothing happens and I cannot switch it off from the on/off button. many thanks
                            • jwilliams1967
                              • Apr 2014
                              • 54
                              just had another look and its +33volts on pin 13 missing .will investigate
                                That is for the tuner and should not cause your fault.
                                • jwilliams1967
                                  • Apr 2014
                                  • 54
                                  hi tom thanks for that buddy . just wasted time tracing the circuit to find out it leads to components which are not present. what should I check next my friend?
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    tom would those inverter connecters if fitted wrong to the psu board as in previous post cause it? you understand the schemes more than me one plug has more wires than the other.
                                      Probably not - I suspect it's made for either two independent inverters or in this case a master-slave inverter (the slave does not need the ON/OFF or DIM signal, it comes from the master directly.)
                                      • jwilliams1967
                                        • Apr 2014
                                        • 54
                                        Hi tom . vinceroger says in his post that he thinks I have some voltages misiing. I have check against the circuit diagram and cant see them. can you shed some light on this please?
                                        • cheeky2
                                          by cheeky2
                                          05-25-2024, 03:27 AM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • ygorsan
                                          by ygorsan
                                          🧩 Problem Summary:
                                          • I
                                          07-28-2025, 08:34 AM
                                        • Asraf Atb
                                          by Asraf Atb
                                          01-27-2025, 05:02 PM
                                        • JSin21
                                          Compatibility of main boards between different variations of samsung MU6100
                                          by JSin21
                                          Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                                          I have Samsung Smart TV UA65MU6100WXXY version DA01
                                          Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                                          11-27-2023, 04:54 AM
