Samsung LN46A530P1 solarized picture
  • splitcrete
    • Dec 2012
    • 387
    • usa
    Hi everyone I have this tv that I saved from the land fill . I have read on many threads that the gamma chip will cause this kind of picture, and I checked service menu for main board settings check OK . I have changed the main board as it had a broken antenna input on it. Then I changed the T-CON with one from e-bay. I still have a bad picture. I ordered some gamma chips AS15-s and changed it being careful not to pull off the pads. Now I have the same picture. I have the gamma volts and the power board volts plus pictures. Any help would be appreciated.
  • splitcrete
    • Dec 2012
    • 387
    • usa
    Re: Samsung LN46A530P1 solarized picture
    More Pics.
      Which set of voltages is your current & which is your new? First pic is definitely bad, second also looks bad, but not quite as bad.
        One other trick: I haven't yet verified it but I think it will work. If you check the REF voltages below the gamma IC, they should (within a few percent) match the VGAMA points.
        • splitcrete
          • Dec 2012
          • 387
          • usa
          That is the voltage from cn801
          • splitcrete
            • Dec 2012
            • 387
            • usa
            I'll check the ref points and post results.
            • splitcrete
              • Dec 2012
              • 387
              • usa
              Here is a picture of the VGAM points compared to the REF points. A close up of the points on the board.
                It's hard to be sure, then, they're a close match.
                Tomorrow, I'm getting a 37" Sony with a bad AS15 IC, and I will go about comparing REF to VGAMA.
                • splitcrete
                  • Dec 2012
                  • 387
                  • usa
                  I did a 42" Sony with a bad AS15 IC, and had no problems .The picture came right back. So what do you think about my voltages should I be getting a normal picture ?
                    The voltages look OK, it is possible they are bad but it is close. I do not think the picture would look that bad, if that were the case. So, time to look elsewhere...
                    • splitcrete
                      • Dec 2012
                      • 387
                      • usa
                      I already re soldered the LVDS connections. I have tried all the inputs. No cold solder joints
                      That is the third IC I put on that board. Could it be I got bad ICs from China? Maybe the cable? Where would you start testing tom ? I don't want to part this tv out not knowing if any boards are bad,that just wouldn't be right.
                      • Alastair E
                        Chief Womble
                        • Mar 2013
                        • 1963
                        • U.K.
                        What does the set look like--with its original mainboard?
                        TELEFIX
                        • splitcrete
                          • Dec 2012
                          • 387
                          • usa
                          It looks the same. I tried changing the settings in the service menu and only gets worse. Maybe I should take the IC off and try a different one. I soldered it on at 600 deg. F , and used 60/40 solder. Should I try a different setting on my station ? I don't want to mess up the pads they are so small and look like they will lift off very easy.
                            09-07-2024, 05:50 AM
                          • TR103
                            by TR103
                            - it keeps rebooting
                            01-22-2025, 04:12 PM
                          • JJAAMM
                            by JJAAMM
                            Problem
                            07-06-2023, 06:01 AM
                          • Mgiffune
                            by Mgiffune
                            06-09-2024, 10:28 AM
                          • Dodgethis
                            Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                            by Dodgethis
                            Hello all,
                            This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                            09-11-2024, 07:39 AM
