hi guys trying to repair this. problem is when you plug in and it goes to switch on screen flashes then powers back off again then tries to boot back up. gives a few flashes of the power red led then led goes off and when tv should be on it displays nothing, no light or anything etc coming from screen.
Samsung PS51E450 Plasma Problem.
Tags: None
Re: Samsung PS51E450 Plasma Problem.
Look at LED on logic board - does it flash continuously once a second, or once every 5 to 7 seconds?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
tom its not doing either. its flashing every 2-3 sec then another flash a second later.. heres a link to see i uploaded to youtube to give you and idea of what i mean.
https://www.youtube.com/watch?v=Z2Vz2Jth7lYComment
Patience, I do have a life outside of badcaps.
OK, I think Samsung have changed the pattern for E-series panels (2012.)
That looks like an error code to me.
I would check Vs/Va on power board.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
ok tom had to switch the tv on and off a few times to get voltages, its as if there is a surge going through it every few seconds so tried to catch volatges but they where all jumping between 0v to what is listed below.
VS 0.07v
VS 0.07v
NC 0v
VA 0v
GND
D15v 14.49v
D5.3v 5.24v
GND
VS-ON 3.15v
VS-CON 0.74v
PS-ON 3.32v
GND
hope this helpsComment
Ok, now unhook Y- and X-main board power connectors and repeat the test, check voltage on power board end. Does Vs rise higher?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
disconnected those boards Tom, the 2 VS at 0.07v very slowly rises back up to that rather than jumping aboutComment
OK so far from what you've told me I'm thinking power board problem.
Can you provide a close up picture of the power board & I will highlight any necessary tests.
I would probably suggest a new power board - for a new TV like this they are likely to be cheap.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I have another board exact same as this pulled from a 43 inch model but all voltages seem to match. Could I try that ?Comment
Board from 43" wouldn't be strong enough for a 51" It just wouldnt supply the current needed--although very similar, I'll bet the Vs transformer is smaller on the 43" PSUTELEFIX
PLEASE DO NOT EMAIL ME PRIVATELY FOR REPAIR ADVICE. QUESTIONS BELONG ON THE FORUM!Comment
It seems this PSU gets its on/off signal through the "X-main" (although calling it that is a bit of stretch, there's hardly anything on it...) That then might come from the Y-main or control board.
Can you get a picture of the labels around the X-main and Y-main connectors?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Yes - is there another connector running from X-main to the bottom panel boards or to the control board?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
X-main right hand side board in that photo, I think there is one connector hiding behind the main board. Please locate it.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
OK, can you get a listing of the labels near that connector; or a picture of them?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
by theone111I have an LG Plasma TV 60PM6700 for the past ~12 years.
In the last ~3-4 months I have been having some issues.- Problem: It started with random picture disappearing (sound still worked).
Solution: Had to turn off TV wait a few seconds before turning it on again. - Problem: Then it got worse and the TV started to shut down and when turning on the no picture just sound.
Solution: Had to turn off TV wait about 10-20 seconds and turn it on again to solve. - Problem: TV shuts down
1 Photo - Problem: It started with random picture disappearing (sound still worked).
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by howardc64Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable... -
by bcstedtJust starting to crack into this one and wanted to get the ball rolling.
At power on (plug in), power light on, relays click, repeat (sometimes)
After disconnecting Y-Main from SMPS power stays on and boot up jingle is heard from speakers
Removed Y-Main for inspection and testing
This pic from:
PN50C540G3FXZA Fast Track Troubleshooting Manual - Rev 1/10/12
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
- Loading...
