HELP PLS! Anyone repaired a Panasonic Viera TV?
  • tw2005
    • Oct 2011
    • 6458
    Re: HELP PLS! Anyone repaired a Panasonic Viera TV?
    Yes I think I saw that in AVS ? Too chicken to touch it except to verify it's existence. that was when I was trying to convert a 50" board to 42".
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
      by sam_sam_sam
      After all of...
      07-13-2024, 08:14 PM
    • canadaboy25
      Panasonic TC-P54VT25 No image. A or D board?
      by canadaboy25
      I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
      The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
      I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
      01-17-2021, 01:06 AM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
