TEAC 2633A(blows fuse)
  • Amraks
    • Nov 2011
    • 725
    The tv came with a blown fuse and dpts switch removed both replaced.
    Now I can get a standby light when I turn the power on(not mains) out of standby, then the main fuse will blow.
    Looked over this board for shorts.
    Not sure were to go next as the capacitors look good.
  • Amraks
    • Nov 2011
    • 725
    Re: TEAC 2633A(blows fuse)
    is it ok to test bridge rectifies in circuit.
      You can do that. Does the board have a relay on it? Pictures of the board would be nice.
      • Amraks
        • Nov 2011
        • 725
        I have not pictures of the board at this current time will take some tomorrow.
        I have tested the bridge rectifier is the middle pins meant to read zero both ways?
        Yes board seems to have a relay if RE1 means anything.
        According to service manual..
        2. When the RE1 is on, the power (90-264VAC) will be transformed into sine wave
        by DB2. The C27 will be charged by D3 at first, not by T3, to avoid the C27 charge
        saturation, which may cause hardware damages such as MOS JM1 failure.
        • R_J
          • Jun 2012
          • 9547
          The Schematic shows a relay, so something is shorted after it. could be DB2 (bridge Rectifier) or JM1 FET (my money's on that), or anything else in that circuit.
          The standby circuit is seperate from the main power supply.
          • Amraks
            • Nov 2011
            • 725
            its prick getting this bridge rectifier out its attached to a heat sink and there is a transformer right in front of it tried for 4 hours trying to remove the lot on the heat sink.
            I think its my iron tip thought its a pointy tip and plus a bit oxidized, waiting on my new handle.
            So anyway of testing JM1 in circuit.
            • Amraks
              • Nov 2011
              • 725
              Ok I have tested the mosfet
              PIN
              1. to pin 2. .OL
              1. to pin 3 .OL
              2. to pin 3 is 26.3 ohms
              So this is the suspect failure?
              This is the mosfet
              11N60C3
              GDB550
              • Amraks
                • Nov 2011
                • 725
                I did a test on the mosfet it tested good.
                switches on and off like its meant too..
                so this would mean that its not a failed part and we can move on?
                • R_J
                  • Jun 2012
                  • 9547
                  Here is the schematic of the power supply
                  • Amraks
                    • Nov 2011
                    • 725
                    Hey from my understanding of testing bridge rectifiers here are my results.
                    Starting with positive on DC-
                    pin2~ 0.506v
                    pin3~ 0.000v(this means its shorted or bad don't it?)
                    reversed negative on DC-
                    pin2~ .OL
                    pin3~ .0.000v
                    Moving on with positive on DC+
                    pin2~ .OL
                    pin3~ .OL
                    reversed negative on DC+
                    pin2~ 0.512v
                    pin3~ 0.511v
                    to my understandings this rectifier is bad am I correct? or have I tested wrong.
                    • martino
                      Not so "senior"
                      • Aug 2013
                      • 997
                      • canada
                      http://www.youtube.com/watch?v=dqkT6hF0O3E
                      Proud owner of dozens of broken TV's and many,many,many boards.
                      Our website and passion:http://hollenhundshepherds.com/
                      • martino
                        Not so "senior"
                        • Aug 2013
                        • 997
                        • canada
                        Wouldn't it be easier to quickly remove transformer,hence creating way more space to remove rectifier?
                        • Amraks
                          • Nov 2011
                          • 725
                          removed that to get to it should of thought of it sooner.
                          Also them results are from the rectifier out of circuit.
                          • Amraks
                            • Nov 2011
                            • 725
                            Got a reading on the sine wave pins
                            1 2 3 4
                            Positive on pin 2
                            negative on pin 3
                            Not a reading reversed.
                            so this confirms it broken rectifier.
                            Where can I find RS 606
                            • martino
                              Not so "senior"
                              • Aug 2013
                              • 997
                              • canada
                              Yes,it's broken,one of 2 diodes that sits between pin 2&3 is shorted,therefore you measure it as if it was just one diode..
                              Where to get? Mouser,ebay etc would have them,but I don't know it is in australia for getting stuff out of states etc... Local electronic store near you???
                              • Amraks
                                • Nov 2011
                                • 725
                                I ordered some but ended up finding one, that was the same rating in a computer psu.
                                the tv is now working. have had it on for about 50 minutes so far with no fuse blowing.
                                Thank you all that have helped. I think I learned how to test a bridge rectifier now.
                                I can not wait for a new iron handle for my soldering station. as the iron i am using is a plug in the wall one with no temperature control sucks and damaged a few traces I was lucky to be able to fix these.
                                • martino
                                  Not so "senior"
                                  • Aug 2013
                                  • 997
                                  • canada
                                  cONGRATS ON THE FIX!!!
                                  • corrize
                                    A funny fuse story – Lumix LX100 II
                                    by corrize
                                    Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                    I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                    The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                    There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                    And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                    10-19-2023, 09:58 AM
                                  • jesterace
                                    Samsung UE46ES8000 Blown fuse but no other signs of short
                                    by jesterace
                                    Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                    09-11-2024, 03:14 PM
                                  • jshhh
                                    Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                                    by jshhh
                                    Hi guys,
                                    I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                                    How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                                    Anybody know how to remove this type of fuse?
                                    (The fuse is toward the bottom of the image labeled F2)...
                                    06-17-2025, 01:35 AM
                                  • Babbar
                                    by Babbar
                                    04-12-2024, 01:12 AM
                                  • fharris1977
                                    Vizio D50u-D1 Dead Set No Standby
                                    by fharris1977
                                    Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                    12-28-2023, 10:25 AM
