LN46a550 Picture Debug
  • Rlcrisp
    • Apr 2014
    • usa
    Hey Everyone,
    Hoping for some advice on leads in troubleshooting an LN46a550 with picture issues.
    I've reseated the TCON cables, cleaned the contacts, I also checked the tab bonds and added thermal pads to the three leftmost vertical bonds. I couldn't really get the behavior to improve at all by doing strain relief or thermal relief of the tab bonds, particularly the leftmost one.
    The picture issue is limited to the leftmost side of the screen most of the time, but it is possible to get picture dependent horizontal lines as well. This is most noticable when pulling the menus up - it is possible to get horizontal lines across maybe the leftmost 1/3 of the panel.
    No obvious damaged parts on PS or main board. Checked voltage through fuses and looks good.
    Any other ideas? Looks like I can get a TCON board for about $25, think it is any chance to have that be the issue? It worries me that it may just be the panel driver because of the localization.
    Any help is appreciated!
    http://i.imgur.com/VI2OeLy.jpg?1
    http://imgur.com/VI2OeLy&oIqXYjY#1
  • Glitcher
    • Mar 2013
    • 673
    • USa
    Re: LN46a550 Picture Debug
    I had a smaller Samsung lcd with the same problem, turned out some water had got onto the board bonded to the panel itself. If you could figure out which component went bad on the board maybe, but I would say panel is bad as well.
    • Rlcrisp
      • Apr 2014
      • usa
      I'll take a look at the circuitry on the circuit board connecting to the tab bond and see if anything seems off. I think it's unlikely that the TV is water damaged. I take it this is almost certain not to be a TCON issue?
      Edit: Thanks for the advice so far, by the way.
      • Tr0ll
        by Tr0ll
        Original T-con:
        First replacement T-con:
        10-07-2023, 07:48 PM
      • JJAAMM
        by JJAAMM
        Problem
        07-06-2023, 06:01 AM
      • TR103
        by TR103
        - it keeps rebooting
        01-22-2025, 04:12 PM
      • DynaxSC
        MSI PRO Z690-A DDR4 (MS-7D25) - stuck during boot every second time - debug code 16 & A1
        by DynaxSC
        Hi Folks
        I have an MSI PRO Z690-A DDR4 (MS-7525) which underwent LGA1700 replacement and had a missing resistor in the VRM section. The missing resistor RV170 (49,9Ω) has been resoldered, and I have also replaced a demaged LGA1700 socket.
        Generally the board does boot to Windows, but not always in the first attempt, but after the second attemp to boot the board with Power Button. Also restarting the board from Windows ends up with stuck boot process, but restarting the board again (long push Power Button or switching off and on PSU). Under Windows etherything works
        09-29-2024, 04:27 PM
      • Mgiffune
        by Mgiffune
        I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
        I ordered a supposedly β€˜new' Tcon board this time, and
        06-09-2024, 10:28 AM
