I am not an electronics expert but i try to fix "stuff" instead of just throwing it away. I encourage all my friends to try and do the same. Well, a friend tried to fix his tv.........he brought it to me and i said "yep those caps" need replacing...the bulging ones. We did this together and then the tv worked. It worked for about 4 months then quit working ........we did not replace all the caps on the power supply board just a few. So my friend ordered a repair kit online which contained the following caps:
"This Magnavox LCD TV repair kit consists of 11 capacitors, 2200uf, 1500uf, 100uf, 47uf, 10uf, 6.8uf and 2.2uf. It also has two zener diodes to replace the zener diodes ZD902 and ZD904 on the Power Supply Board."
But after replacing all the caps the tv did not work. Prior to replacing the caps when he would try to turn on the tv nothing happened no led lights nothing. after replacing caps from the kit the led lights come on but no picture.
Note: He did not replace the ZD902 or ZD904. I checked these using a multimeter in resistance setting. ZD902: Measured 2.2Mohm in one direction and 1.9Mohm in the other. ZD904: Measured 2.2Mohm in one direction and infinite in the other
If any of you have any ideas on what to look at please let me know.
if you need additional information please let me know.
