Magnavox MCS225/77 Replacement for UTC1316 or KA2214
  • pabloroggeri
    Electronic
    • Apr 2015
    • 90
    • Argentina
    Hello guys. I need a replacement for UTC1316 or KA2214, in my country I can't get either of them, it is for an inexpensive radio recorder, there is no point in searching for it on e-bay or Amazon. Thank you
  • pabloroggeri
    Electronic
    • Apr 2015
    • 90
    • Argentina
    I forgot to mention make and model: Magnavox MCS225/77
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8340
      Try AliExpress?
        DVR recorder Switching power supply Failure
        When I originally started with my DVR recorder it had 4 individual switching switching power supply’s that were sh*t so I bought a 7 amp 12 volt switching power supply and modified the output plug and put a four output power supply cable to match the input power supply cable inputs
        Which worked for over 14 years until a few days ago when the cameras went dark no picture anymore well it turns out now the switching power supply has stopped working altogether now so I have to troubleshoot what has happened to this power supply more later on today what I found
        This...
        05-27-2023, 03:03 AM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • the_rem
        Unknown transformer : how to find a good replacement part ?
        by the_rem
        Hello guys,
        I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
        I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
        04-23-2025, 01:48 AM
      • tonybig10
        Magnavox MDR515H/F7 And Magnavox MDR537H/F7
        by tonybig10
        Hi is any one can help me on getting the Schematics for Magnavox MDR515H/F7 And Magnavox MDR537H/F7 PDF file thank you I really appreciate it. Just need to change some component on
        the main board and the power supply board. I looked all over for the internet and I cannot find the Schematics sheet for both of them. I don't know where else to look I hope someone can help me...
        03-07-2025, 01:03 PM
      • ezenia
        PS4 controller left stick potentiometer replacement issue
        by ezenia
        Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
        So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
        I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
        09-30-2023, 02:19 PM
