MAGNAVOX 47mf437b37 No picutre
  • Welchs101
    • Sep 2008
    • 979
    I am not an electronics expert but i try to fix "stuff" instead of just throwing it away. I encourage all my friends to try and do the same. Well, a friend tried to fix his tv.........he brought it to me and i said "yep those caps" need replacing...the bulging ones. We did this together and then the tv worked. It worked for about 4 months then quit working ........we did not replace all the caps on the power supply board just a few. So my friend ordered a repair kit online which contained the following caps:
    "This Magnavox LCD TV repair kit consists of 11 capacitors, 2200uf, 1500uf, 100uf, 47uf, 10uf, 6.8uf and 2.2uf. It also has two zener diodes to replace the zener diodes ZD902 and ZD904 on the Power Supply Board."
    But after replacing all the caps the tv did not work. Prior to replacing the caps when he would try to turn on the tv nothing happened no led lights nothing. after replacing caps from the kit the led lights come on but no picture.
    Note: He did not replace the ZD902 or ZD904. I checked these using a multimeter in resistance setting. ZD902: Measured 2.2Mohm in one direction and 1.9Mohm in the other. ZD904: Measured 2.2Mohm in one direction and infinite in the other
    If any of you have any ideas on what to look at please let me know.
    if you need additional information please let me know.
  • wills123
    • Jan 2014
    • 72
    • england
    Re: MAGNAVOX 47mf437b37 No picutre
    diodes shouldt have a reading in both directions only one, do you have diode test function on meter? if so use that, might have to desolder the diode that reads both ways and test out of circuit to confirm its faulty
    • Welchs101
      • Sep 2008
      • 979
      will do......
      using multimeter diode test function:
      ZD902: ~ 0.55V
      ZD904: ~ 0.54V
      • Welchs101
        • Sep 2008
        • 979
        oh wait......but i measured those "in circuit" i did not take them out......do i need to take them out? if so just let me know......
        • anotherdude
          • Feb 2013
          • 488
          wouldn't it just be easier to replace them considering you already have the parts?
          • Welchs101
            • Sep 2008
            • 979
            yes, i can replace them but i dont have them at the moment. Did not know he had those as well........but can we not tell something from the measurements i made if the diodes are good or not? just hate to wait a few days to get the parts from him, put them in , and then be right back where we started..........but hey i am the one asking for help so if thats what you want me to do i guess beggers cant be choosy.......
            • anotherdude
              • Feb 2013
              • 488
              but if you have to test them out of circuit, then you'd be able to replace them easily anyway
              sorry if I came across as abrupt
              • Welchs101
                • Sep 2008
                • 979
                no problem..........my friend is going to come over one night during the week and we will put the diodes in together then.......will keep you updated on the progress.
                thanks.......and no worries!
                • hfox
                  • Aug 2014
                  • US
                  Sorry to jump in on your discussion, but I have the identical problem and using the same kit of capacitors and diodes, I replaced all of them. The power led will go to green when I turn on the set and stay on, but there is no light from the screen. I measured the 12 volt power section and it is fine. However the 24 volt section shows 2.3 v with no load. I am looking for another source of the problem. Thanks for any assistance.
                  • tonybig10
                    Magnavox MDR515H/F7 And Magnavox MDR537H/F7
                    by tonybig10
                    Hi is any one can help me on getting the Schematics for Magnavox MDR515H/F7 And Magnavox MDR537H/F7 PDF file thank you I really appreciate it. Just need to change some component on
                    the main board and the power supply board. I looked all over for the internet and I cannot find the Schematics sheet for both of them. I don't know where else to look I hope someone can help me...
                    03-07-2025, 01:03 PM
                  • sudz28
                    Magnavox 27MS5402/17 CRT - no picture, flashing green light
                    by sudz28
                    I'm going to assume my beloved Magnavox CRT is toast, but also figured maybe this was a good opportunity to dip my toes into he circuitry waters and maybe learn something new. Also, I don't want to trash it if it's a fairly cheap/easy fix!
                    My 20-year-old Magnavox has gotten me and my kids through many a gaming console change and worked great up until the other day. Following a long distance move, it sat in our garage for a year and now that I brought it in and turned it on I get no picture; instead, a green light blinks on the front of it; 7 flashes, one long flash, then 3 more...
                    02-08-2022, 10:09 AM
                  • barrybahr
                    Magnavox 32MD350B/F7 getting a false on/off control voltage
                    by barrybahr
                    The unit is stuck in an intermittent on/off cycle. When I plug in the power cord, the green "On" light activates without any command, flashes for a few seconds, then turns off. The red standby light comes on for a few seconds before the cycle repeats. During this time, I cannot turn off the unit manually; it will shut off automatically after about five minutes, and there is no picture. Occasionally, with repeated attempts to power it on, I eventually get a picture and sound, which function properly. When it does work, I measure several voltages, and they appear to be normal....
                    04-20-2025, 10:30 PM
                  • pabloroggeri
                    Magnavox MCS225/77 Replacement for UTC1316 or KA2214
                    by pabloroggeri
                    Hello guys. I need a replacement for UTC1316 or KA2214, in my country I can't get either of them, it is for an inexpensive radio recorder, there is no point in searching for it on e-bay or Amazon. Thank you
                    08-28-2024, 10:34 AM
                  • gilbert009
                    I need help identifying the issue with my Magnavox MDR513H dvd recorder!
                    by gilbert009
                    Hello! I am fairly new at repairing electronics. Recently I came across an old Magnavox MDR513H dvd/hdd recorder. It is not powering on. When the unit is plugged in, I get this really annoying beeping sound coming from the power supply.. I have already tried things like unplugging the unit for a few hours, holding the power button for a minute or 2. Nothing seems to make It work.
                    I found this guy with the same problem on YouTube -https://www.youtube.com/watch?v=iFVm-SJX-S8
                    I checked all over this video's comments but no one really helps him with the issue. except...
                    12-01-2021, 04:04 AM
