TNPA4250 Board Repair
  • canadaboy25
    What is normal?
    • May 2013
    • 509
    Re: TNPA4250 Board Repair
    Well I soldered a wire to SOS7 and shorted it to ground but the TV just shut off sooner that it did before. I tested the voltage between SOS7 and ground and there was around 2.8 volts if that means anything...
    canadaboy25
    -Sometimes the light at the end of a tunnel is an on-coming train
      If you remove that, is it all as before?
      • canadaboy25
        What is normal?
        • May 2013
        • 509
        Yes it's exactly the same as before.
        canadaboy25
        • canadaboy25
          What is normal?
          • May 2013
          • 509
          The little power indicator on the SC board is off when the wire is shorted.
          canadaboy25
            That's odd, I'm wondering if the control board expects it to go high then low (it does on a working board.) Perhaps try grounding it when it powers on but just before it cuts out.
            The light indicates the ER circuit is operating, by the way, which generally means the panel is being sustained (made to light up)
            • canadaboy25
              What is normal?
              • May 2013
              • 509
              Well I've been poking around and found the problem, I didn't have the power plugged into the SC board... my bad (no wonder the indicator light wasn't lighting up)
              I plugged the board in and shorted the test point to ground and the TV stayed on.
              Am I supposed to retest the SC output with my oscilloscope now?
              canadaboy25
              • tw2005
                • Oct 2011
                • 6457
                For me, remove the shorted sos7, obviously with no sc2 connected it would trip 7, retest if stays on and picture good I'd leave it at that provided no other adjustments have been made unless you want to double check what the voltages are set too but if you never changed them then i would expect it to be good
                  Yes, test SC output, any picture on screen, even if poor?
                  • canadaboy25
                    What is normal?
                    • May 2013
                    • 509
                    I will test the output today.
                    From what I can tell there was nothing on the screen at all.
                    canadaboy25
                    • canadaboy25
                      What is normal?
                      • May 2013
                      • 509
                      Well while I had the panel lifted looking at the screen I heard a snap like a high voltage spark and the TV shut off.
                      Now it won't stay on even with the test point shorted.
                      canadaboy25
                        I think that's the risk you get when you disable an error detect, something could go pop.
                        • canadaboy25
                          What is normal?
                          • May 2013
                          • 509
                          The board does still stay on when I unplug the data cable so it there any way that I can still test it?
                          I had the ground lead of my oscilloscope connected to the heatsink on the SC board and the tip of the probe may have (I'm not completely sure) made contact with one of the via's on the SU board. The reason I suspect this is because there was a slight blackish soot mark (like the one made from a large spark) near the via (the probe was also close to here).
                          I don't think that the SU board is the problem because the symptoms do not change when it is removed.
                          I also don't think that something just went pop from being overloaded for too long because I had previously had the board powered up for much longer with no issues that the time when it got zapped.
                          Stupid mistake on my part but I hope that there is still something that I can do.
                          canadaboy25
                          • canadaboy25
                            What is normal?
                            • May 2013
                            • 509
                            It may also be worth noting that the TV now blinks 5 times when it shuts off.
                            canadaboy25
                            • canadaboy25
                              What is normal?
                              • May 2013
                              • 509
                              I have followed the troubleshooting guide on your website and I have narrowed the fault down to the 5v supply on the power board. (It said replace the P board but I'm not about to do that)
                              So basically i ruined the 5v rail. How would I go about testing the power board?
                              canadaboy25
                              • canadaboy25
                                What is normal?
                                • May 2013
                                • 509
                                Sorry I was wrong. I went and took the power board off and took off a bunch of parts and tested them and everything was testing fine. I eventually put the board back in and tried it again and it turns out I counted the blinks wrong.
                                It is blinking 6 times which means SC energy recovery circuit. I have no idea what that is but it is still on the SC board.
                                canadaboy25
                                  Does the green LED ever glow?
                                  • canadaboy25
                                    What is normal?
                                    • May 2013
                                    • 509
                                    Yes, the green indicator on the board lights up when I turn it on.
                                    canadaboy25
                                      Does it go out before the relay clicks and you get SOS6?
                                      • canadaboy25
                                        What is normal?
                                        • May 2013
                                        • 509
                                        The green light stays on after it flashes. It stays on even after I unplug the TV and only shuts off once all the power stored up in the capacitors and stuff drains out.
                                        canadaboy25
                                        • canadaboy25
                                          What is normal?
                                          • May 2013
                                          • 509
                                          The green indicator light is lit up on the board on the other side of the TV too.
                                          canadaboy25
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • Hakuu
                                            by Hakuu
                                            Hi There,
                                            More Details
                                            TV Model - LG OLED77G1PUA
                                            07-12-2023, 02:37 PM
                                          • jb_Bak
                                            by jb_Bak
                                            CN6401
                                            Pin 01 NC
                                            Pin 02 NC
                                            Pin 03 "BL_ON": 0V
                                            Pin 04 "N/C"
                                            Pin 05 "STBY 3.3V": 3.5V
                                            Pin 06 "GND": N/C
                                            Pin 07 "AC_OFF"...
                                            09-27-2021, 04:52 PM
                                          • canadaboy25
                                            Panasonic TC-P54VT25 No image. A or D board?
                                            by canadaboy25
                                            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                            The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                                            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                            01-17-2021, 01:06 AM
