help with samsung pn58b550 plasma
  • mattstolte
    • Dec 2013
    • 612
    • usa
    Re: help with samsung pn58b550 plasma
    Originally posted by tom66
    That marks the adjustment point, but we're still looking for a place to test it. Since 3-4 jumper did not work, it is unlikely to be a main board fault.
    But what we just tested is the main logic control the tcon correct? And I don't even think it connects to the main after u disconnect the lvds cable so how did we check the main? Or it woulda turned on if the main was bad huh?
    • mattstolte
      • Dec 2013
      • 612
      • usa
      also what place do u want me to check it at? I checked all voltages on them and there correct? So I don't know what to do now. Could the main logic control be bad? By unplugging all the buffers and scan drive y sus,zsus shouldn't I have gotten a picture somewhere?
      • mattstolte
        • Dec 2013
        • 612
        • usa
        So tom what should I do next? I'm lost now
          If the main board (with HDMI etc on it) was bad you would have got some test patterns on the screen with that 3-4 jumper.
          Yes you could have a bad logic board (or "main logic" if you like) but as you have a flashing light (meaning its processor is running and trying to control the plasma panel), it's unlikely, so for now, I'm suggesting checking elsewhere and that is why I want you to find Vscan or Vsc test point and check it. It will be on there somewhere!
          If Vscan/Vsc is missing it points towards a bad Y-buffer or Y-main board.
          Don't shot-gun replace stuff UNTIL you've found the problem, or you'll be hundreds of dollars in and it still won't work.
          • mattstolte
            • Dec 2013
            • 612
            • usa
            Tom I'm sorry I'm dragging this out but I have no idea where these test points are??? All them pictures I added on page 1 is not it? I don't even know what it looks like if u could show me an example picture maybe? Thanks for all ur help
            • mattstolte
              • Dec 2013
              • 612
              • usa
              #26
              Tom im at my shop now can u tell me what to look for on this plasma?
                not sure, I just recalled this thread and we couldn't find it either, see this image for some quick checks
                https://www.badcaps.net/forum/attach...1&d=1390928806
                • mattstolte
                  • Dec 2013
                  • 612
                  • usa
                  #28
                  tom is this anything you wanted to see?
                    I have a feeling Vscan might be indicated by that arrow... but that could also be the DIP flow direction, so.... not sure. Nice of Samsung to make it so very clear as mud.
                    • mattstolte
                      • Dec 2013
                      • 612
                      • usa
                      #30
                      so in that picture am I putting my probes on each side of that coil?
                      • mattstolte
                        • Dec 2013
                        • 612
                        • usa
                        #31
                        and on the connector am I putting my negative probe on lead 3 and positive on lead 11?
                          the red capacitor, not the coil.
                          red lead on red, black lead on black.
                          • mattstolte
                            • Dec 2013
                            • 612
                            • usa
                            #33
                            what about in the picture of the connector?
                              As you said. Do that.
                              • mattstolte
                                • Dec 2013
                                • 612
                                • usa
                                #35
                                on the cap im getting -110 on my meter??? on the connector im getting nothing.. and while I was testing it I smelled something really hot on that board burning
                                • mattstolte
                                  • Dec 2013
                                  • 612
                                  • usa
                                  #36
                                  also how can I discharge that board with out getting shocked? or am I ok? im gonna take it off and look at the bottom
                                  • mattstolte
                                    • Dec 2013
                                    • 612
                                    • usa
                                    #37
                                    tom you think I should get new y main?
                                      I haven't made my mind up yet because I don't have all the requested information...
                                      Negative reading for the caps is fine, depends on which way you put the probes & which way I've indicated it... 110V does indicate that part of Y-main is fully functional. If you listen carefully you might be able to hear a slight buzz from the board. This is OK.
                                      • mattstolte
                                        • Dec 2013
                                        • 612
                                        • usa
                                        #39
                                        I hear slight buzz from y and z sus's. what other info do you need? remember I am new to this so all this is new to me, thanks
                                          The Vsch I highlighted across those pins for one...
                                          • alltvrepairs
                                            Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                                            by alltvrepairs
                                            I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                                            I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                                            Any one met this problem in the past?...
                                            10-08-2025, 07:34 AM
                                            09-07-2024, 05:50 AM
                                          • Asraf Atb
                                            by Asraf Atb
                                            01-27-2025, 05:02 PM
                                          • bcstedt
                                            Samsung PN50C540G3FXZA 50" Plasma, power cycling, Y-Main problem, Canada
                                            by bcstedt
                                            Just starting to crack into this one and wanted to get the ball rolling.
                                            At power on (plug in), power light on, relays click, repeat (sometimes)
                                            After disconnecting Y-Main from SMPS power stays on and boot up jingle is heard from speakers
                                            Removed Y-Main for inspection and testing
                                            This pic from:
                                            PN50C540G3FXZA Fast Track Troubleshooting Manual - Rev 1/10/12
                                            12-15-2023, 10:30 AM
                                          • JSin21
                                            Compatibility of main boards between different variations of samsung MU6100
                                            by JSin21
                                            Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                                            I have Samsung Smart TV UA65MU6100WXXY version DA01
                                            Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                                            11-27-2023, 04:54 AM
