help with samsung pn58b550 plasma
Re: help with samsung pn58b550 plasma
also what place do u want me to check it at? I checked all voltages on them and there correct? So I don't know what to do now. Could the main logic control be bad? By unplugging all the buffers and scan drive y sus,zsus shouldn't I have gotten a picture somewhere?Comment
So tom what should I do next? I'm lost nowComment
If the main board (with HDMI etc on it) was bad you would have got some test patterns on the screen with that 3-4 jumper.
Yes you could have a bad logic board (or "main logic" if you like) but as you have a flashing light (meaning its processor is running and trying to control the plasma panel), it's unlikely, so for now, I'm suggesting checking elsewhere and that is why I want you to find Vscan or Vsc test point and check it. It will be on there somewhere!
If Vscan/Vsc is missing it points towards a bad Y-buffer or Y-main board.
Don't shot-gun replace stuff UNTIL you've found the problem, or you'll be hundreds of dollars in and it still won't work.Last edited by tom66; 04-14-2014, 03:15 PM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Don't shot-gun replace stuff UNTIL you've found the problem, or you'll be hundreds of dollars in and it still won't work.Comment
Tom im at my shop now can u tell me what to look for on this plasma?Comment
not sure, I just recalled this thread and we couldn't find it either, see this image for some quick checks
https://www.badcaps.net/forum/attach...1&d=1390928806Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I have a feeling Vscan might be indicated by that arrow... but that could also be the DIP flow direction, so.... not sure. Nice of Samsung to make it so very clear as mud.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
so in that picture am I putting my probes on each side of that coil?Comment
and on the connector am I putting my negative probe on lead 3 and positive on lead 11?Comment
the red capacitor, not the coil.
red lead on red, black lead on black.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
also how can I discharge that board with out getting shocked? or am I ok? im gonna take it off and look at the bottomComment
I haven't made my mind up yet because I don't have all the requested information...
Negative reading for the caps is fine, depends on which way you put the probes & which way I've indicated it... 110V does indicate that part of Y-main is fully functional. If you listen carefully you might be able to hear a slight buzz from the board. This is OK.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Negative reading for the caps is fine, depends on which way you put the probes & which way I've indicated it... 110V does indicate that part of Y-main is fully functional. If you listen carefully you might be able to hear a slight buzz from the board. This is OK.Comment
The Vsch I highlighted across those pins for one...Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by Asraf AtbHi everyone,
I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....1 Photo -
by bcstedtJust starting to crack into this one and wanted to get the ball rolling.
At power on (plug in), power light on, relays click, repeat (sometimes)
After disconnecting Y-Main from SMPS power stays on and boot up jingle is heard from speakers
Removed Y-Main for inspection and testing
This pic from:
PN50C540G3FXZA Fast Track Troubleshooting Manual - Rev 1/10/12
by JSin21Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
I have Samsung Smart TV UA65MU6100WXXY version DA01
Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...4 Photos -
by BiruslapioHello, the problem with this TV is it has all the Y and X voltages, but does not produce any image.
It had a TON of cracked solder joints on these boards, fixed all that I could find, but in the last test I forgot to plug in the Y-SUS to control board flat cable, it was left dangling and possibly some pins shorted to the panel metal ground, the X-Main buzzed quietly then blew up in 3 seconds after powering up, annoying.
Two RJH30E2 shorted, they are 360V 35A 1.7VCE IGBTs, the problem is I don't have any 360V IGBTs, only 300V or 600V, would two RJP3065 fit in? It's... - Loading...
