Lg 42ld520
  • abeeftec
    • Mar 2014
    • 43
    Lg 42ld520
    My TV is fine once it heats up. But it has an issue that was a horizontal one fifth of the bottom of the screen at first. Then when I left it off for a week when I turned it back on the same issue was 98 percent of the screen with a little strip at the top where I could see my Computer Mouse move.
    I use my TV for a monitor and it has been mostly on for 3 and a half years.
    The lines actually go vertical inside of a horizontal problem.
    That bad percentage part of the screen becomes unresponsive while the good percentage part is fine.
    Also, it takes two times hitting the power button to get the TV to come on.
    Then the light which should be blue goes out. Even when the TV finally heats up and works the light goes out and stays out.
    Any idea what this issue is?
  • R_J
    • Jun 2012
    • 9624
    Re: Lg 42ld520
    I have one like this, The fault is on the main board around ic603,Possibly C653? I have not isolate the problem yet as the set started working again.
    When it acted up there was a good picture about one inch from the top and the rest was lines etc.
    If I find the exact component causing this issue I will post.
    • abeeftec
      • Mar 2014
      • 43
      Re: Lg 42ld520
      Thanks RJ
      I still have the same issue but as long as the TV stays on it is fine and the screen shows fine.
      But now I have another problem.... whenever I am watching videos the power on the monitor just goes off for about 2 seconds and then comes back on and plays again only to do it again.
      It does it for hours and then stops and goes days without doing it only to start happening again.
      Does anyone have any idea about this LCD TV?
      • rounin
        MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
        by rounin
        I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
        🛠 Original Issue
        The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
        ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
        04-19-2025, 01:18 AM
      • ugamazing
        Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
        by ugamazing
        I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
        We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
        12-17-2024, 07:05 PM
      • shahnld
        Lenovo legion 5 pro startup issue
        by shahnld
        Good day Experts
        I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
        A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
        And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
        08-24-2025, 12:31 PM
      • ahmarzo
        Acer laptop battery draining issue
        by ahmarzo
        Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
        Help me to diagnose this issue as there is no shortage in the inputs MOSFET
        08-02-2025, 06:39 AM
      • elmark
        HP 15-cw1002ua strange keyboard issue
        by elmark
        HP Pavilion 15-CW1002UA
        S/N 5CD0251CBC
        P/N 7KE54EA
        Hello guys!
        I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
        It powers on OK and has no other issues except the following:
        • CAPS LOCK does not work at all
        • Fn button toggles Flight Mode
        • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
        • (with SHIFT pressed: 't%' and 'y^' respectively)
        I initially thought it was a keyboard malfunction (internal short, etc.),
        but when I press and hold...
        06-27-2025, 01:10 AM
