32MF301B/F7 No power, several bad parts on PSU
  • johnboy1313
    • Nov 2012
    • 1959
    I posted in this thread, but it seems like it's not getting any attention, so I'll post again here.
    https://www.badcaps.net/forum/showthread.php?t=25477
    I picked up a Magnavox 32MF301B/F7 with the same no power issue and same PSU. Unlike the original poster, my fuse wasn't blown. R602 and R611 (labeled R601 right next to R602 in the hand drawn schematic) were both failed open. I'm guessing that based on the hand drawn schematic provided by budm in the link below, the open resistors saved the fuse. Being that the fuse is good, I'm wondering if the lightbulb trick would work in this case.
    https://www.badcaps.net/forum/attach...9&d=1358581659
    I also found the following failed components.
    Q600 shorted
    D604 shorted
    D607 shorted
    D610 shorted
    D640 shorted
    R608 open
    R605 and R606 are both giving weird readings in the KOhms out of the board, so I'm replacing those as well.
    Once those are replaced, if any other component is shorted, the lightbulb trick should then work, correct?
    Re: 32MF301B/F7 No power, several bad parts on PSU
    https://www.badcaps.net/forum/showth...t=25477&page=4 see post 73.
    You may also want to read Kevin comments:
    https://www.badcaps.net/forum/showth...t=25477&page=6
    Its been awhile so I do not remember all the details. Use the lamp when you install all those new parts.
    • johnboy1313
      • Nov 2012
      • 1959
      Thanks Bud
      • johnboy1313
        • Nov 2012
        • 1959
        I replaced what I found to be bad components but the lamp still lights. I found that with D610 removed, I still see a dead short between the two holes that the diode solders into. It looks like the cathode of D610 connects to R608 and Q600, the anode connects to HOT ground. Q600 and R608 both test good. What should I look at next?
        Schematic
        https://www.badcaps.net/forum/attach...4&d=1361833980
          D610 will read short, it has 0.2 ohm in parallel.
          The diodes on the output aren't shorted?
          • johnboy1313
            • Nov 2012
            • 1959
            I'm not really sure which diodes are the output diodes (D605 and D609???). I've checked all of the diodes on the hot side and none show shorted.
              The output diodes are the ones on the secondary/cold side.
              • johnboy1313
                • Nov 2012
                • 1959
                I've tested every diode on the board. I can't find anything shorted. I'm at a loss here.
                  Permanent glow from lamp or just flashing? To try to narrow down the short, with the bulb installed, you can check for voltages across components. Any power components with near zero volts across them could be shorted. Try testing across one of C602, C603 or C604. What do you measure? Also, try seeing if you get any output - try isolating the main board in case of a short circuit too.
                  Also, if Q601 is bad, the transistor will never turn off, so the circuit will act short continuously. Could have been damaged if Q600 main power FET blew.
                  See theory of operation described elsewhere:
                  This is a self-oscillating PSU (ringing-choke converter)
                  * The initial startup pulse comes from the 220K Rs R603, R604, R600.
                  * Once the MOSFET begins conducting (Vgs>2V) current flows through T600 pins 3-5 building a field up in the transformer.
                  * The sudden increase in primary current causes a reflected current across pins 7~8 of T600 which drives the gate fully into saturation (about 20V) limited by zener D604.
                  * Once the primary current hits a certain limit (defined by approx 0.7V/R608), the transistor Q601 will start discharging the MOSFET gate.
                  * As the MOSFET gate discharges below the threshold the primary current begins to drop and this causes a large negative pulse across pins 7~8 of T600 which rapidly discharges the FET gate, improving efficiency.
                  It's quite a clever circuit, but it has no intelligence. It'll do it's best to drive a dead short, like a shorted output diode, quickly resulting in the destruction of the MOSFET due to overcurrent or overstress.
                  https://www.badcaps.net/forum/showth...t=36180&page=3
                  • johnboy1313
                    • Nov 2012
                    • 1959
                    Permanent glow from lamp. C603 and C604 are not installed. I'll check C602, I'll have to solder leads to the cap to be able to test it.
                    Thanks for the idea with the main. It seems obvious now, but I probably wouldn't have ever thought to try that.
                    I've tested Q601 out of the board twice. It is not shorted.
                      If Q601 is OPEN it would also cause a problem... Use a transistor tester or just plain replace it as it's a 5¢ component.
                      • johnboy1313
                        • Nov 2012
                        • 1959
                        Replaced Q601 and still have the lamp on. Not sure where to go from here. I may just put it under the bench.
                        • johnboy1313
                          • Nov 2012
                          • 1959
                          Well, I finally got back to this one. It's been sitting since May. I decided to throw the fuse back in and see what would blow. I plugged it in and it came to life. I just finished watching Back to the Future on it. It's wierd because substituting a lamp for the fuse would cause the bulb to glow. I thought that meant that something was still shorted and that the fuse would blow.
                            What Wattage of the lamp did you use? 100W will be fine if the main power is not activated and just in standby mode, otherwise you will have to use more than 200~300W LAMP.
                            You have to play with wattage of the lamps to get the ideas what size lamp you will need when you work on the stuff.
                            • johnboy1313
                              • Nov 2012
                              • 1959
                              Ahh, I don't think it was even a 100W lamp. Thanks for the tip.
                              • johnboy1313
                                • Nov 2012
                                • 1959
                                Just fixed another one of these. It needed...
                                Q600
                                Q601
                                R608
                                D607
                                D610
                                D640
                                Fortunately, these parts were all spares. I bought two of everything last time.
                                • reessi
                                  Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                                  by reessi
                                  Hello:
                                  I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                                  I started on the ACER:
                                  Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                                  All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                                  I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                                  10-29-2024, 11:31 AM
                                • modtool
                                  HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
                                  by modtool
                                  Hi to all,
                                  the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
                                  I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
                                  I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
                                  04-01-2025, 08:22 AM
                                • BalkanBoy
                                  Dead Razer Blade 14 2022, shorted CPU?
                                  by BalkanBoy
                                  today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
                                  Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
                                  I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
                                  Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
                                  I removed coil and injected 0.7V, it draw around...
                                  09-27-2024, 12:44 PM
                                • barry101
                                  Apple 820-3662 VCore shorted to ground.
                                  by barry101
                                  Hi, Would appreciate some help.
                                  I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                                  Get charger light but no fan spin or chime. No liquid damage.
                                  Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                                  Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                                  With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                                  Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                                  06-24-2025, 07:34 AM
                                • guizmo1967
                                  Dell Latitude 5501 LA-H181P shorted power rail
                                  by guizmo1967
                                  This is my problem:
                                  Laptop: Dell Latitude 5501
                                  Motherboard: EDC51 LA-H181P
                                  I have two power rails shorted to ground, +1.0V_PRIM and +3.3V_ALW_PCH. I removed solder on PJP302, +1.05VALWP (pad1) not shorted but +1.0V_PRIM (pad2) shorted.
                                  I also cleaned PJP38, pad1 not shorted, pad2 (+3.3V_ALW_PCH) shorted to ground.
                                  I measure the resistance of all the coils on the motherboard and they all were not shorted to ground except coil PL301 before I removed the solder on PJP302.
                                  I injected +1.05V - 2A...
                                  07-25-2023, 06:56 PM
