Panasonic TC-P42X1 Plasma 12 Blinks
  • kevinm34232
    • May 2012
    • 1884
    Re: Panasonic TC-P42X1 Plasma 12 Blinks
    No nothing arced and it worked until I tried to reset the ribbons. Oh well this TV is a mess
    • kevinm34232
      • May 2012
      • 1884
      Final question on this one, the only way TV will stay on is if remove all connections to SC and SS. Tried isolating SD and SU with same 7 blinks. So SC went bad?
        Or you have an A board fault and it's just got worse, would also explain part picture. Try heating the A board up maybe?
        • tw2005
          • Oct 2011
          • 6458
          AS in sd/su disconnected and SC50 jumpered?
          • kevinm34232
            • May 2012
            • 1884
            Yes SD/SU disconnected and SC50 jumpered I still got 7 blinks.
            • jm1234
              Panasonic plasma TX-P42ST50 - 6 blinks
              by jm1234
              anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
              It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
              I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
              I checked that board for any obvious faults...
              05-22-2024, 06:59 AM
            • Alicat
              Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
              by Alicat
              Stopped by this site trying to fix my parents Panasonic Plasma TV.
              Model number is TH-50PZ85U
              Power comes on and the red power light stays on solid.
              Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
              I also hear a few clicks.
              I also think my parents said there was a thunderstorm and the TV failed after that.
              Section 6 in the service manual talks about power and no screen,...
              10-30-2024, 10:09 AM
            • nick31
              Panasonic Plasma ST50 TC-P55ST50 P55ST50 8 blinks
              by nick31
              My Oct 2012 panny plasma quit working yesterday.
              It was on when it happened. It let out a bit of burned plastic/circuit board smell. I was not able to find any burned parts though.
              Now it produces 8 blinks. According to the repair manual, that points to SS/SS2 board(s).
              I completed the steps in the guide: unplugged SS33, the TV turned on with a black screen, no blinking codes. Then I checked the continuity between pins 1 and 2 of the connectors SS52, SS54-SS57. The continuity is ok in all of them. Guide suggests to replace SS/SS2 boards so I placed an order...
              04-21-2021, 09:56 AM
            • stecos
              Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
              by stecos
              Hi everyone!
              I happened several times, in the search for help from the web, to consult this very interesting forum.
              So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
              Having said that I come to the gist of my post on the forum as the title suggests.
              For my passion for technology I'm now collecting several...
              11-28-2022, 11:39 AM
            • Biruslapio
              Panasonic P50VT20B Plasma 12 Blinks, Power Supply or A-Board?
              by Biruslapio
              Hello, I've had this TV for 3 years, 2 years ago it stopped working signaling 12 Blinks, SOUND_SOS according to the service manual.
              It has no VSUS or VDAT, and P15V has 1.0V instead, the same 15V goes to A board. F15V is ok and other main voltage rails.
              It seems the power supply is defective, since unplugging D20 ribbon cable that goes from D-board to SC-board makes the behavior change, the TV stays on, there's no image nor VSUS, but 15V reads 2.4V, high enough to not trip the SOS 12 blinks, so it stays on, fans do not spin but I left it 2 hours, green led lit up...
              02-16-2021, 09:44 PM
