Philips 42PFL5432D/37 PS 715T2432-3
  • mavrick2k
    Learning
    • Mar 2014
    • 14
    • US
    Tried repairing this set already. Looked at common problems and threads related to these systems. I replaced all Aluminum caps including the high voltage, diodes ZD902 & ZD904, and rectifier D922. The set powered up fine went through menus and all was great. Bought a wall mount for bedroom, mounted and hooked it up and powered it on and got the chirping and no display again.
    First time through i debated replacing D926 because it was only showing around 200 with the meter but did not. It is now showing dead. D922 that i replaced is also showing shorted again along with d927.
    I never paid much attention to the bottom of the board first time around but noticed small diodes on bottom. which meter says one is low and other is shorted. D915&D919. They look to be buggers to replace and have no part number for ordering. Guess it all comes down to should i keep messing with this sucker or is it a lost cause. Has anyone had similar issues with these things. If i do attempt to replace these other parts what are the chances that all the caps are still good. they all look fine.
    Stupid People are like Slinky's. Not really good for anything but they bring a smile to your face when you push them down a flight of stairs.
  • philliesfan30m
    • Aug 2013
    • 542
    Re: Philips 42PFL5432D/37 PS 715T2432-3
    i had that problem but mine was a little different just like all tv fixes aren't gonna be the same each time. this is just an idea to me c945 looks like it got hot at 1 time and c921 looks like it is bloated a little unless it is just the pic. my fix was d912 that was making it chirp and after replacement it has been fine for quite some time now that doesn't appear to be the same problem.
      D915 is for the MOSFET Gate discharge circuit, it is connected in parallel with 100 Ohms resistor, so it will show up as bad on your meter due to the 100 ohms resistor in parallel with the Diode.
      If you can circle those diodes you replaced, it will help me figure what they are for, I having a hard time locating using the pictures.
      • mavrick2k
        Learning
        • Mar 2014
        • 14
        • US
        In green are the parts i have replaced. In red is what i am thinking about replacing. Plus at least two of the small diodes on the back of the board.
        • mavrick2k
          Learning
          • Mar 2014
          • 14
          • US
          Dont think i would need the Q902 after testing again. Saw someone else had replaced it. Just getting to the point I will try just about anything.
          • mavrick2k
            Learning
            • Mar 2014
            • 14
            • US
            Well i figured out my problem. Could not figure out how most of the components on the 24V side seemed shorted. Started to remove them and they all tested goo out of circuit. Knew something went fishy. Traced it back to that rectifier. Some dumbass (being me) when replacing the rectifier removed all old thermal paste to replace with new nicer compound. What they forgot to do was put the plastic isolator back between it and the heat sink. Since the back is metal and the heat sink is grounded out it created my short on the whole 24V side. Put plastic back in and set working great on the wall in the bedroom.
            • Dvsr
              On M-Audio AV40 active studio speaker's two zener diodes get really hot.
              by Dvsr
              Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
              I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
              After replacing the caps I started testing out the speaker. It seemed...
              09-10-2025, 10:20 AM
            • caspian
              What Zener Diodes on a Linear Power Supply
              by caspian
              Dear members,
              I have a linear variable power supply with unknown brand name that I used for voltage injection.
              Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
              In addition, I discovered that its zener diodes are defective.
              I can replace the burned transistors.
              But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
              Therefore, I cannot replace the zener diodes.
              I do not want to test the zener diodes in a test circuit to discover their model or value.
              no schematics are available...
              05-26-2025, 12:38 PM
            • crozoki
              Philips 65PUS6554/12 one time backlight flash
              by crozoki
              Hello
              I have Philips 65" TV (65PUS6554/12).
              Problem is when turn on tv backlight flash only one time for about 1 second then turns off and display is dark but sound is there.
              Sometimes TV turns on and work with no problem, had backlight and picture, but mostly Tv wont turn on backlight. Any idea where to start looking?
              Power board TPV 715G9187-P01-008-001S
              Main Board 715G9907-M01-B03-005K...
              09-03-2022, 05:47 AM
            • tvguy12012012120
              by tvguy12012012120
              02-07-2025, 05:13 PM
            • ahmedtou
              HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
              by ahmedtou
              help me please
              I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
              When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
              I will share all the details with you, including the disc information.
              Code:
              HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
              Current Profile: BD-R
              Disc Information:
              Status: Empty
              State of Last Session: Empty
              Erasable: No
              Free Sectors: 12,219,392
              Free Space: 25,025,314,816 bytes
              Free Time: 2715:27:17 (MM:SS:FF)
              Next
              08-27-2025, 08:49 AM
