Tried repairing this set already. Looked at common problems and threads related to these systems. I replaced all Aluminum caps including the high voltage, diodes ZD902 & ZD904, and rectifier D922. The set powered up fine went through menus and all was great. Bought a wall mount for bedroom, mounted and hooked it up and powered it on and got the chirping and no display again.
First time through i debated replacing D926 because it was only showing around 200 with the meter but did not. It is now showing dead. D922 that i replaced is also showing shorted again along with d927.
I never paid much attention to the bottom of the board first time around but noticed small diodes on bottom. which meter says one is low and other is shorted. D915&D919. They look to be buggers to replace and have no part number for ordering. Guess it all comes down to should i keep messing with this sucker or is it a lost cause. Has anyone had similar issues with these things. If i do attempt to replace these other parts what are the chances that all the caps are still good. they all look fine.
