Emerson E320VT power supply problem
  • David53
    • Aug 2013
    • 36
    I just can not seem to get away from defective power supplies in Emerson/Funai branded Tvs. Anyone have a schematic or know the value of Q501 and R501 in the power supply. The board is a A21F1MPW. Thanks very much.
    David
    Re: Emerson E320VT power supply problem
    Emerson E320VT is that the correct brand and model?
    E320VT is VIZIO: http://www.walmart.com/ip/Vizio-E320...ished/21777180
    • David53
      • Aug 2013
      • 36
      I posted the wrong Model No it is an Emerson and the correct model number is LE320EM3. How can I change the thread title to the correct Model? I do have a vizio with the E320VT model number I am working on also. I typed the wrong model number in the header. Sorry.
      • David53
        • Aug 2013
        • 36
        Re: Emerson LE320EM3 power supply problem
        Emerson Model number is LE320EM3 Can moderator or someone fix this post to reflect the correct model number I have posted here?? Thanks
        David
        Last edited by David53; 03-28-2014, 02:01 PM. Reason: Correcting an incorrect model number post by me
        • Larrygad7
          • Apr 2014
          • united states
          David
          David, this is Larrygad7, the value for the resistor is 47ohms 1watt 5% that is
          R501 the Q501 is K3498. I hope this helps. Larry
          • David53
            • Aug 2013
            • 36
            Thank you Larrygad7 your help is most appreciated.
            David
              03-31-2024, 02:12 PM
              07-01-2024, 06:34 AM
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • JimBanville
              Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
              by JimBanville
              The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
              I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
              09-13-2023, 07:21 AM
            • shamsudeen
              Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
              by shamsudeen
              Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
              I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
              i know that in linear power supply the noise will be very low comparing to SMPS supply....
              07-19-2025, 07:14 AM
