Insignia 50" plasma, clicking and standby only
  • Evenflow
    • Mar 2014
    • 38
    • US
    I have an Insignia Model: NS-51P680A12
    Died while watching. Plug it in clicks, standby blinks then remains solid. I disconnected x-main from y, as they are chained, and pluged in and got sound and remote seems to work but no pic. Anyway I ordered a new x-main. Does this sound right? And there is a small board attached to bottom of x with 2 ribons going to panel. I cant find this board. What are the chances it's bad??
  • tw2005
    • Oct 2011
    • 6458
    Re: Insignia 50" plasma, clicking and standby only
    That will be an extender board or X-buffer. usually there's nothing on them except maybe a cap so unlikely anything wrong with it.
    • Evenflow
      • Mar 2014
      • 38
      • US
      Ok. Thanks. Does it sound like an x-main problem?
      • nwelec
        • Dec 2014
        • 61
        • usa
        I know this has been a few years but was the x-main the problem?
        • B0r1s
          Samsung UE49KS7000SXXH - fast clicking sound in standby mode
          by B0r1s
          PSU - BN44-00878A
          Symptoms:
          The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
          A weak clicking sound was coming from the transformer.
          Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
          Progress:
          After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
          01-17-2023, 04:58 PM
        • XCon
          LG 60PN6500 Plasma with standby, but won't power up.
          by XCon
          Symptom is TV has standby, I get relay click, voltage rails come up, but no screen and TV shuts down after 5 seconds. If I disconnect the Z from the y sus, the unit stays powered up and I can read voltages.
          So I've read the two other threads on this TV and I can confirm the Y-Sus #EAX64789501 does not have diode or resister failure. Did not see any fractured solder joints on the transformer or anywhere else. All power boards have slight discoloration on the hot spots.
          The board in question is EAX64789601, Z board. I have 208 going to Y Sus, 5v standby. Pin 5 on P174 connector...
          06-27-2025, 05:30 PM
        • rju
          Samsung 60" Plasma TV, Blinking Standby LED
          by rju
          A sports bar/restaurant with ~40 Samsung Plasma TVs. This is the 2nd TV that has a blinking standby LED. I'd like to learn how to repair these TVs because I'd guess that over time more and more of them will develop this symptom. My hope is to repair the bad PCB, however if that's not realistic then I'd replace the bad PCB.
          Model PN60F5300AF, Type PN60F5300, Model Code PN60F5300AFXZA
          Upon applying power, the red standby is steady. When I tap the power button, the standby LED immediately blinks twice, then it blinks once ~ every 4 secs. Also, Upon applying power, the...
          07-21-2020, 05:23 AM
        • bffargo
          2014 LG 60" Plasma shut down just clicking unless I disconnect 17V line to main CPU
          by bffargo
          LG 60PB66550 NOV 2014
          PSU: EAY63168603
          PCB: EAX65359531 2013.11.01 Rev:1.0
          Main board: EAX65399305(1.0) 13.11.27 PU42A/PA42A/PD42A
          Symptom:
          While watching, just went black and started clicking relay every few seconds.
          Initial diagnosis:
          Removing JUST the main CPU/Input PCB from circuit stops the clicking. No problems with any other boards/drivers. (Removing all other boards and only putting Main back in is all it takes to start clicking again)
          Deeper diagnosis:
          Pulling pins #1/#2 (Blue/Grey) from the connector housing...
          09-09-2022, 07:34 PM
        • meeotch
          Samsung PN64H5000 clicking when powered, then stuck in standby
          by meeotch
          My PN64H5000 shut itself off/on/off a few times in succession last night, then refused to turn on again. When I first plug it in, I get five clicks coming from the power board, and the red standby light on the front goes on and off, as does the little green LED on the logic board. After that, the red standby light comes on after a couple of seconds and stays lit, but the TV will not power on. Confirmed by leaving it unplugged overnight.
          I opened it up, and didn't see any bulging caps, burnt PCBs, or anything else obvious. Tested the two fuses I saw on the power board (one removable,...
          09-27-2021, 02:57 PM
