Panasonic TC-P50G20 Vieracast freezes tv
  • mag89pie
    • Mar 2014
    • 10
    • united states
    Hello all. I have a TC_P50G20 that is about 4 years old. Never had any issues until the last month. It started out when I would watch Netflix, the screen would freeze. When I pressed exit, the power supply would click, the screen would go black, but the LED would stay lit. I would have to hold the power button for 10 seconds to get it to come back on.
    Now when I hit the viera cast it will start to load the apps and then freeze. Nothing on the remote works but the power. If I turn it off the power supply doesn't click but it turns off. When I power it back on, still no power supply clicks, the screen comes up and plays but everything is locked up (remote controls) until I hold the power down for 10 seconds.
    All other inputs appear to be working correctly.
    The only other oddity is when I hit the menu button, the menu screen has some stray variations, like pixelations. Does this sound like the modem board? Is the modem board the same as the DG board? Thanks, any help is appreciated.
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P50G20 Vieracast freezes tv
    Any pictures of the issue? What is netflix? Is that through the ethernet connection on the TV?
    If you go into the menu, should be able to find out what firmware revision this has.
    Sounding like an A board issue but need more info. Is TV function and Av normal ?
    I don't use the internet feature on my V20.
    • tw2005
      • Oct 2011
      • 6458
      "Menu",
      Select "Setup" and press "OK"
      Scroll down to "about" (on the next page),
      Select "About" in "Setup Menu",
      Select "Version" and press "OK"
      • tw2005
        • Oct 2011
        • 6458
        Originally posted by mag89pie
        ....... If I turn it off the power supply doesn't click but it turns off. ...........When I power it back on, still no power supply clicks, ....
        Is that just by the remote and you're powering off and back on straight away?
        That's normal but if you turn off by remote after about 30 secs or so you will hear the relay release and then if you power on after that it will click again on powerup.
        • mag89pie
          • Mar 2014
          • 10
          • united states
          version 0150-7330. Yes internet apps through viera cast. I was using the Panasonic wifi dongle, but today I unplugged it and used the LAN connection. Remote or power on tv do the same, unless I hold tv power down for 10 secs.
          • tw2005
            • Oct 2011
            • 6458
            Hmmm, must be different other there. I was thinking maybe worth trying a firmware update.
            latest version is Ver. 3.750. for US
            Mine is 3.607 `(oceania) which i can work out looking at the software version?
            http://panasonic.jp/support/global/c...down_navt.html
            How stable is the TV if you use it normally?
            the only risk with doing this is if your TV freezes or if there is some other issue and the firmware does not write to the eeprom, then you may end up with a bricked TV.
            I've done mine with no issues but your call.
            depends how important netflix is to you.
            It may not fix it but it seem to be an A board issue so you may have to replace it anyway assuming you can find one.
            might be worth contacting panasonic or an agent in case the board could be reflashed to fix it?
            not something I've read here before.
            • tw2005
              • Oct 2011
              • 6458
              looks like netflix was added on this update.
              Sep. 2, 2010
              Ver. 3.00 1.Capable of playing back 3-D video content stored on a SD card using Panasonic's Camcorder. (VT Series)
              2.Adds support for VIERA cast (Netflix) in USA market.
              So could be a firmware issue??
              • tw2005
                • Oct 2011
                • 6458
                So it sounds like that application is locking the A board up. Not much you can do I don't think except replace A board or try loading the firmware again but realsie the risk of no TV at all if it goes wrong.
                If this has to be fixed probably worth the risk as either way you'll need an A board but you probably need advice from a qualified panasonic tech just in case it's a known issue with a fix.
                • mag89pie
                  • Mar 2014
                  • 10
                  • united states
                  Ok, i decided to live with out my apps and netflix. TV worked fine for about 10 days, now it wont come on at all. I am looking into ordering the A board. To be sure, the A board is the board with power button, hdmi, av, coax connects. correct? When i order this board does it come with any firmware? or do I have to manually install?
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    Looks like a power supply issue to me...
                    A working TV? How boring!
                      All modern Panasonics seem to have issues with the BGA processor or RAM causing random lockups; could it have just been a symptom of a wider problem?
                      • tw2005
                        • Oct 2011
                        • 6458
                        So it does not turn on but is there a blink code generated by the front LED?
                          LCD LED TV Service Menu Codes
                          TCL LED TV Service Menu Code
                          LG LED TV Service Menu Code
                          10-31-2024, 03:58 AM
                        • BigPete
                          Panasonic Heatpump Dryer Repair
                          by BigPete
                          I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                          The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                          In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                          Unfortunately the whole machine has to come apart to fix it.
                          I have...
                          11-01-2025, 06:40 PM
                        • Andre Gilbert
                          by Andre Gilbert
                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                          11-20-2024, 08:52 PM
                        • Robby-Gr
                          TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
                          by Robby-Gr
                          I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality β€” very close to the original.
                          However, since the swap, the TV enters a boot loop (Samsung logo β†’ restart) unless I enter the service menu and perform a reset.
                          The service mode had been previously modified β€” possibly by a technician or during the panel swap β€” and I suspect some key settings are mismatched for the European (Greece) market.
                          Additional issues:...
                          09-27-2025, 12:02 AM
                        • Retro140
                          Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
                          by Retro140
                          So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
                          To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
                          06-18-2023, 06:13 PM
