LG 26" LCDTV 26LC7R input problem
  • eauyong
    • Sep 2008
    • 18
    Please advise any ideas to solve this problem which will be much appreciated.
    The details of this TV is as follows:
    LG LCD TV model 26LC7R-TB
    Product code: 26LC7R-TB.ATCGLJD
    Manufactured: November 2007.
    The TV could not start up so I open it up and found 4 leaking caps as shown.
    It was replaced by PANA caps.
    Bad caps were from SAMWHA as follows:
    680uF 35V 3pcs replaced by Pana FR equivalents.
    3300uF 10V 1pc replaced by Pana FM equivalent.
    The TV can now be started up easily but there is a new problem.
    Selecting TV and Component-1, the full colour and tint is normal but upon selecting the rest (AV-1, AV-2, Component-2. RGB/PC, HDMI-1 and HDMI-2, full colors will not be displayed and a purple tint is predominant.
    I can deduce that the TV works fine except that some input section have problem.
    I attached photos showing the power, main board, all the input screens and the bad caps.
    Any advice would be much appreciated.
  • tw2005
    • Oct 2011
    • 6458
    Re: LG 26" LCDTV 26LC7R input problem
    So what happens when you actually hook up a source and have video running through it on each of those inputs?
    • tw2005
      • Oct 2011
      • 6458
      Maybe each input has had it's picture mode set? Try picture reset or select each source and go into the picture menu and see if it's been tailored.
      • eauyong
        • Sep 2008
        • 18
        I have reset all and try all settings but to no avail.
        Usual connections are HDMI-1 and Component-1 which I attached the photos which shows the differences.
        • tw2005
          • Oct 2011
          • 6458
          well that's absolutely weird, great picture otherwise. one would have to assume mainboard issue, corrupted settings who knows. IC500 gets a mention in the manual for incorrect display but???
          • eauyong
            • Sep 2008
            • 18
            Problem solved. One setting I missed out is the picture mode. Changed to "Standard" instead of "Dynamic". Thanks tw2005.
            • ugamazing
              820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
              by ugamazing
              So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
              1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
              2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
              04-10-2024, 08:06 AM
            • hugocarmo
              Panasonic TX-24A1UN CRT Sound and Input problem.
              by hugocarmo
              Hi.
              I´ve been given an old CRT from Panasonic, it´s almost new, it was storaged and almost not used since bought.
              It is imaculate inside, almost no dust or debris inside.
              The picture is good, but I have no left sound channel, I tried all the inputs, outputs, even on headphone jack. In AV2 I hear sound from right channel but no image, on tv tuner only right sound channel, the same for AV1.
              So I started to look for a service manual, I found one, and started from the beginning.
              Most of the times the caps are the problem so I orderer all the caps for all boards,...
              04-26-2025, 07:45 PM
            • theone111
              by theone111
              3. Problem: TV shuts down
              07-22-2024, 10:36 AM
            • falcontech
              Yamaha Msr400 Input Board Problem
              by falcontech
              Good morning everyone
              I have a problem with this input module of an active speaker of the Yamaha (MSR400), the signal transmitted by this unit and sent after the EQ module and then end up the amplification form is lower than normal, I attribute the problem to this Module because with that of the twin box works perfectly, I thought of the three capacitors highlighted in the photos and that I have not yet replaced or the operational highlighted NJM2860L, the strange thing I noticed that by trying with the jack by pulling it a little out of the normal position the earnings is normal, while...
              04-06-2023, 09:44 AM
            • Zeonalbasta
              Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
              by Zeonalbasta
              i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
              The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
              09-13-2024, 01:17 PM
