rca 42pa30rq no picture but everything else good
  • shawn76
    • Mar 2014
    • 15
    • usa
    I have no picture but everything else is working. Totally responsive remote to change channels and inputs. sound is fine. led light on the outside is fine. one click when turned on like always has. read a bunch of threads and am thinking of swapping x and y boards. I do not have the electric reader tools to check for blown anything. took the back off and everything visually looks good, nothing melted or swollen capacitors . I would appreciate some advice though,thanks.
  • shawn76
    • Mar 2014
    • 15
    • usa
    Re: rca 42pa30rq no picture but everything else good
    This is a plasma with the samsung parts inside.
    • Mgiffune
      by Mgiffune
      06-09-2024, 10:28 AM
    • Tr0ll
      by Tr0ll
      Original T-con:
      First replacement T-con:
      10-07-2023, 07:48 PM
    • jason123
      QN55Q80 backlight good no picture
      by jason123
      got this TV for a friend to look at. Non-responsive to PWR button. Main board gets warm, the the optical audio light is on. Faul pin is zero volts. I am getting 33v on Vdrive. 12.76V on B13 & A13. Vamp is 17.3V.
      Disconnecting panel cable to main - no change. Disconnecting small ribbon from main to led driver board, backlight comes on.
      Do do you guys think? I am thinking main board issue?...
      09-14-2025, 03:59 PM
    • TR103
      by TR103
      - it keeps rebooting
      01-22-2025, 04:12 PM
    • jord4231
      Toshiba 37AV500A Regza TV good power supply no sound no picture
      by jord4231
      Hi Everyone,
      I'm working on a Toshiba 37AV500A Regza TV.
      The issue:
      TV was working picture and sound went out. Green stand by light stayed on, It will respond to the power button being pressed (goes in and out of standby)
      The TV will very intermittently work for around 40 mins then stop. This doesn't seem to matter if its hot/cold unplugged for a while etc.
      I checked the PSU voltages and everything looked good.
      No bulging caps or signs of heat.
      24v aud = 24.41v
      12v = 11.98v
      5v = 5.062
      p_o/f = Goes high...
      03-29-2022, 09:21 PM
