samsung UN55ES8000FXZA intermittant lines
  • superg
    • Dec 2013
    • 58
    • Barbados
    Hi All
    This TV has intermittant vertical green lines throughout the entire screen. I replaced the T-Con, main board and the ribbon cable connecting the two boards. The client got the parts but when I replaced them the TV came on with the image upside down. After about an hour going through the system menu trying to rectify this the original fault came back, intermittant vertical green lines throughout the entire screen. Any ideas?
  • freakaftr8
    • Oct 2012
    • 3743
    Re: samsung UN55ES8000FXZA intermittant lines
    Do you have a picture of the fault? It sounds like the lcd panel itself could be faulty. With the original boards was this intermittent?
    • superg
      • Dec 2013
      • 58
      • Barbados
      Yes it was intermittant with the original boards
      • freakaftr8
        • Oct 2012
        • 3743
        Yes I would say there is some kind of panel fault. Are the green lines going vertical and move with the images on the screen?
        • superg
          • Dec 2013
          • 58
          • Barbados
          they are vertical and there is no image when they appear.
          • freakaftr8
            • Oct 2012
            • 3743
            Ok. So the image dissappears? Would really like to see a picture of the fault when it is happening to determine further.
            • superg
              • Dec 2013
              • 58
              • Barbados
              ok, will see to that later.
                09-07-2024, 05:50 AM
              • Falki
                Colorful LCD Vertical Lines on Samsung ue55es8090
                by Falki
                Hello there, ive recently found an older 55inch Samsung SmartTV.
                Sadly it has vertical lines at the left and one line in the middle-right.
                I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
                I have factory resetted the TV as well but also with no luck.
                I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
                A similar issue has been posted as well but also with no actual response ...
                08-12-2025, 04:19 AM
              • fulepost@outlook.com
                Samsung "QE" series QE55Q70RATXXC Intermittant restart in "home mode".
                by fulepost@outlook.com
                Dear all.
                I'm a less knowledgable member who would appreciate some guidence.
                I have a Samsung QE55Q70RATXXC that works perfectly in "shop mode" but in home mode it restarts, Intermittantly.
                With intermittant I mean the TV can work perfectly for a week and suddenly start to restart. Before the restart it may reach different stages. Sometimes it restarts when the "QLED" start screen shows up and some thimes it restarts after hours, and everything in between.
                When the restart occurs, the screen blacks out leaving a light area alomng the edges fading...
                11-09-2025, 07:10 AM
              • Rubenlily
                Samsung QE50Q67TAU - horizontal lines
                by Rubenlily
                First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
                I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
                I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
                I'm no expert but I've done the tape...
                08-16-2023, 01:12 PM
              • jeyoung12
                Samsung QN50Q60t lines on screen
                by jeyoung12
                Hi all
                I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                So....i don't know what end of the C ribbon to work with...
                02-26-2024, 10:38 AM
