Panasonic Viera TC-P50S30 parts
  • bobbyd40
    • Dec 2012
    • 116
    • usa
    Son threw game controller at it.All boards are good.What i have listed below.
    1.TNPA5351 with both su and sd boards.
    1.TNPA5357
    1.TNPHo914 tuner board
    1.TNPA18-19-20
    1.NOAE6kk00005 or J11o5e power supply
    I would like to trade one or some of these board for a board i need TNPA5105
    Best way to get me is by text or email
    text 313477 9116
    email bobbyd40@aol.com
    Re: Panasonic Viera TC-P50S30 parts
    Just be aware the SU and SD boards could be bad if the screen was cracked while powered up. You can test them:
    http://www.youtube.com/watch?v=51SZsfH60EY
    • tw2005
      • Oct 2011
      • 6458
      Still trying to get that TNPA5105? It was a 50S2 you had? https://www.badcaps.net/forum/showthread.php?t=25861
      TNPA5105AB Just noticed they have a sale on 25% off
      http://www.moduslinkptstvboards.com/txnsc1lquu/
      Repair & return $137.90 less $34.48
      $103.43
      i guess you're not into having a go at component level repair on it?
      http://www.shopjimmy.com/panasonic-t...repair-kit.htm
      http://www.ebay.com.au/itm/PANASONIC...item1e8565bba6
      http://www.ebay.com.au/itm/15pcs-REP...item417db691be
      http://www.ebay.com.au/itm/PANASONIC...item25757b42b3
      The only issue i have with kits is the assumption that the exact same parts fault or they have it covered with the kit. that may not be the case.
      So with the 4 kits I pasted. All claim to have the parts to fix 4,5,7 blinks but I've seen 10 blink reported then goes 4 blink which is basically shorted vsus.
      Also what GTVWATFORD shows is what genuine parts would look like.
      I have repaired 3 TNPA5081 boards fro the G20. the 5105 is almost the same just cut down a little.
      lots of copycats out there and the prices are getting a bit extreme especially the UK kit. The FET driver IC i think I got them at $4 each, somone is trying to flog them at $12
      • Ama Chur
        Panasonic Viera LC470EUN (SE)(M2) T-Con issue?
        by Ama Chur
        After watching some youtube videos and checking some forums, I'm at a loss. With both ribbon cables connected, we have no image. With the left one pulled out, the screen is black and white, split down the middle. With the right cable removed, it is all black. Backlight is working fine and we have sound and can open applications. We are strapped for money right now and are hoping to repair whatever the issue may be. I think the TV was manufactured in 2012, so I'm aware that may not be possible. Edit: Found a single vertical line of blue pixels on the left side of the screen with one of the ribbon...
        02-21-2025, 08:12 PM
      • BigPete
        Panasonic Heatpump Dryer Repair
        by BigPete
        I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
        The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
        In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
        Unfortunately the whole machine has to come apart to fix it.
        I have...
        11-01-2025, 06:40 PM
      • badcappo
        Dead Panasonic Viera TX-P65STW50 Plasma TV
        by badcappo
        Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
        Diode type G972s6 - D101 with a short
        Mosfet 06N90E - Q301 shorted
        Fuse T5AH 250V - F103 blown
        Diode D301 shorted
        Relay DG1U-17VDC II - RL001 blown
        I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check πŸ˜€...
        11-24-2024, 11:27 AM
      • J8rda7
        Panasonic Viera TX-L50E6E - no image
        by J8rda7
        the TV has a black screen. Sound OK, backlight OK.
        When I measure T-CON voltages, there is VGL+VGH=0V. After unplug the right side of the screen from the T-con, voltages are OK and half screen works normally.
        I tried to search for any kind of short on the right side, but I had no luck. I have a beginner experience in measuring and repairs of the LCD panels..
        Thanks to anyone who can guide me in solving the problem.. and be patient with my english πŸ™‚πŸ˜
        05-13-2024, 11:04 PM
      • Andre Gilbert
        by Andre Gilbert
        Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
        Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
        11-20-2024, 08:52 PM
