RIP M65 Vizio
Vizio M65-E0 No Picture, No Sound
OK, Thanks Lotas. So if I understand you correctly, the T-CON board is faulty supplying the Left Ribbon cable. T-Con boards are "relativity" cheap so it would be better to replace the T-Con board than to try to chase the bad component(s) effecting the Left Ribbon cable power. EazyBone, not quite ready to RIP the M65-E0 but I might wish I had taken your advice later 😉.Comment
Just mask 6-10 pins at a time, generally on the left or right side not usually the middle. Yes it's RIP tv because it's panel short is what I'm saying. I don't think you'll ever get a picture.. but can't hurt to try it out. Just slice a strip, plug it in, if it don't work. Unplug tv, move tape, redo. Always make sure power is unplugged when moving the ribbons.Comment
yours TV will work and have sound with out panel connected.... i wrote before forget VGH VGL or any other related to T-CON.... have sound on the TV first then yours MB PSU are fine.... if you keep suspected panel as other do you will end up to scrap it.Comment
Ahh, well, I have an update. I decided to check the left buffer strips more closely and so I pulled the left leg support off and discovered the problem. The previous owner, for some unknown reason drilled or did something with the left leg support which completely hid the damage to the far left buffer strip. EasyBone, you may be right RIP. I don't know if the buffer strip is 1 layer of multiple layers. If single layer I might try to rebuild the traces (tedious) but I did disconnect the last ribbon cable to the damaged strip and powered on the TV and got multiple red vertical lines. I am enclosing pictures of what I found. Regards,Comment
Yes, you can try, if your eyesight is good, or under a microscope, carefully go through the drimmer, restore the tracks in the opposite direction....
Here the board is multi-layered and the current paths inside the board could be damaged...Last edited by lotas; 09-05-2024, 01:01 PM.Comment
That's odd, drilled through or something. Unless your just bored, throw it away. Even IF you repaired those, remember it was dropped probably and it's probably broken within the panel also .. but I would love to see that repair if you tried.
Thanks for the advice. I will take a long look at it and decide whether to attempt the repair. I'm retired so I have more time than money😄. What concerns me the most is your comment "Here the board is multi-layered and the current paths inside the board could be damaged..." I have magnifiers so I could probably see to solder but it would be like trying to solder a human hair. As I stated earlier, when I tried to power on the TV with the last (damaged) buffer board disconnected, the TV came on without a picture but had a lot of red vertical lines on the screen so even if I do repair the buffer board I'm not sure that would fix it. Regards
lotas, you are right on.👍 I looked at the other end buffer board and just like you said the damage was there only not as bad. I checked voltages at the T-Con now with both ribbon cables connected and the left damaged section of the buffer board disconnected. As follows, VGA, 1= 15.25v, 7= 8.13v, 8=6.97v, 14= .36v. VSSG= -7.95, TDCOM= 8.57, VGH= 30.2, CFCOM= 6.3, AVDD= 16.1, VSSO= -9.5, VCC= 3.2, V12= 12.4. I am enclosing some other pictures, (first one confirms your scenario). Second is the picture of the screen with both ribbon cables connected to the T-Con but the damaged buffer disconnected. Your thoughts? ThanksComment
Some super long bolts. Don't even bother id say. That damage could of shorted everything out and if you got it all connected back together it's still be broken.
I would just look for another TV on marketplace and try and fix that instead!Comment
Assuming...7 Photos -
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
by IerwinHello everyone,
Anyway I still fully expect that there has been something seriously damaged... -
by jchangHi all
I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
Symptom:
No picture no sound.
When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
No sound at all.
What I tried:
1. I tried unplugging the left or right ribbon... - Loading...
