Sanyo DP46840 Audio Power Fail
+ More Options
Posts
  • David_Clark
    • Aug 2012
    • 6
    Hi I've been reading another thread :https://www.badcaps.net/forum/showthread.php?t=20199
    about a very similar problem with this model except my unit will power fail down only when the volume is up past half. When it power fails the voltage out IC1670 to test point 13v drops to 2.8v then 2 seconds later it shuts off. Do you guys think it could be that the same LV5806MX V5806 ic regulator failed?
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Sanyo DP46840 Audio Power Fail
    The regulator could be bad, and it just isn't capable of handling the power anymore...
    Note the post #94 (on page 5), that person has the same 13v drops to 2.8v issue.
    Post #90 (on page 5), that person says there is a service bulletin to replace the regulator and add a zener diode, however he doesn't share any link. That post is from 2012, I doubt he will respond now. (plus that user has only 2 posts... lol)
    Maybe we could find this bulletin online (hopefully!)
    Muh-soggy-knee
    • David_Clark
      • Aug 2012
      • 6
      Thanks for the references Ben7. I cant find the service bulletin anywhere but I ordered two new surface mount regulators. Also I found this: http://youtu.be/KSYCn93pz6k
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • Sus256
        HISENSE 65E7KQ PRO - no boot
        by Sus256
        Hi all!
        HISENSE 65E7KQ PRO
        RSAG7.820.13512 - chassis
        MT9618BAATAB - cpu
        RSAG7.820.12059 - power
        HD650Y3U77 - panel
        KLM8G1GETF - emmc
        Replaced emmc.
        Terminal log
        UART
        AC_ON
        E-B
        FDE enabled
        06-01-2025, 02:11 AM
        03-31-2024, 02:12 PM
